Old 01-22-2009, 04:29 PM   #1 (permalink)
GW: 25346
97 ranger not compatible with scan guage
The scan guage folks have advised that my ranger is not completely compatible with the scan quage and that they do not plan to go to the trouble to fix the problem. The scan quage will not display speed, distance, or fuel economy. Does anyone know what I could do to remedy the problem. I think that I read some where that the 1997 doesn't have a VSS.
I would appreciate any feedback you might provide.
easy
Old 01-22-2009, 04:32 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
If the truck has no VSS, you can add a magnetic pickup to the drive shaft and use it with an MPGuino (I'm assuming it's fuel injected).
Old 01-22-2009, 04:44 PM   #3 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
I seriously considered a '97 2.3L Ranger that was for sale in my area...until I read that it's incompatible with the scangauge.
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
DeepScale
Old 02-14-2009, 02:17 PM   #4 (permalink)
zed sled - '74 Datsun 260Z turbo/MSefi
Franklin - '98 Subaru Forester
Send a message via AIM to myplasticegg
It has a VSS, it is just really weird. The MPGuino will work with an additional component(still learning this myself) In short, the ranger VSS is similar to an AC sine wave and we need a DC wave?
Old 02-14-2009, 02:19 PM   #5 (permalink)
http://ecomodder.com/forum/showthrea...-vss-6956.html
Old 02-14-2009, 08:10 PM   #6 (permalink)
GW: 25346
97 Ranger
Gents,
Thanks for the info. If I understand what your are saying, the magnetic pickup is simply providing a means of by passing the Ford VSS. Just wire it to the mpguino and I'm in business?
easy
Old 02-15-2009, 12:02 AM   #7 (permalink)
You could do that, yes. Or it seems there's a workaround to the issue in the thread myplasticegg posted: http://ecomodder.com/forum/showthrea...-vss-6956.html
09 corolla scan guage results mercury7 General Efficiency Discussion 6 08-29-2008 12:20 PM
