Old 05-24-2009, 03:26 PM   #1 (permalink)
Question b2000 electric fan conversion
im planning on doing an electric fan conversion. i have a 97 neon which i plan to pull the parts off of. wondering if the radiator and fan from the neon will be suffient coolant for my b2000 4 cylinder and what problems I might run across. not worried about the ac plan on removing all the ac components from the b2000.
Old 05-24-2009, 10:20 PM   #2 (permalink)
allc0re's Avatar
The Truck - '00 Ford Ranger XL Ext. Cab
90 day: 24.94 mpg (US)
Send a message via AIM to allc0re Send a message via MSN to allc0re
You are using both the fan AND radiator from the Neon? Why not just use the fan and keep the original radiator on the B2000?
Old 05-25-2009, 01:14 AM   #3 (permalink)
will probably wind up doing that actually. just have to figure out how to set it to come on when is required.
Old 05-25-2009, 10:19 AM   #4 (permalink)
allc0re's Avatar
You might look here. I'm doing the same only on a Ford Ranger.
http://ecomodder.com/forum/showthrea...sion-7147.html
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Electric Fan Conversion (Ford Ranger) allc0re EcoModding Central 13 05-01-2014 10:07 AM
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
Extreme Electric Motorcycle conversion for Publicity/Charity bennelson Motorcycles / Scooters 5 11-18-2008 04:09 PM
