Non-running Solectria / Geo Force worth getting?
1 Attachment(s)
For the sake of discussion in the EV conversion realm, would this already
converted, just missing the batteries, 1993 GEO FORCE be a reasonable place to start? Geo:eBay Motors (item 260514049913 end time Nov-30-09 03:37:25 PST) What would a reasonable estimate (+/- $1K USD) be to get it running? What sort of top speed and range would it get? http://ecomodder.com/forum/attachmen...1&d=1261580296 |
Yeah, I saw that one too! I would buy it if I had the money. Looks like all you need is to put in the batteries. There are a few Solectrias out there, so even if it needs work there are folks that could help.....
Hope you don't mind I split your question off into a new thread.
FYI: http://www.evdl.org/docs/force1994.pdf The Solectria cars aren't run-of-the-mill conversions. They're commercially produced from brand new "gliders" bought from GM. (Which is why this car has less than 5k miles on it.) If the tech in this earlier model is anything like the later ones that I've driven, it's a very slick EV: AC drive, which is both more efficient and equipped with regen. Sufficient power for highway use ~60 mph should be no problem. There's a Yahoo group dedicated to the car, so you would have excellent support from the community of owners if you need it. I'm not sure what the battery pack would cost to replace though. Not up on battery types/prices. Maybe someone else could chime in. If I had the money and wanted to buy rather than build an EV, I'd look for a Force. |
I'd do it. They're rare, first of all. When EV's become the "norm", you might be able to sell it to a collector looking for "firsts" of the type for far more than you paid for it.
If you've got the time and know how, you could make it run on a nice lithium pack, as well... cost is higher, but damn, that's some battery technology. |
I'm pretty sure that I couldn't handle the myriad of details that getting this car on the road would entail... even with outside help. (The pictures of the battery comparments with the odd wires lying about seem particularly worrisome to me) :confused: As you've noted it apears to be a good starting point for someone with the time, covered space, tools and ability to learn new stuff to get started... before the Nissan LEAF arrives :rolleyes: and at maybe half the cost. It's being available -- for some 6 days and some odd hours at any rate --seems like an opportunity to exchange ideas with members at large on what would be needed... reasonable expectations cost estimaes etc. |
That car is worth restoring!
At some point most older EVs are going to need a new set of batteries, this one looks like you can get it for a low price because they are missing... the only advantage that old batteries give you is that you can drive it a few blocks, or drive it on to a trailer and you avoid paying a core charge on the new batteries.
From the photos it looks like the wiring is in good shape and complete so $150-200 per 12v battery and you can drop them right in an in a matter of a few hours have it on the road, if you knew what batteries fit correctly you could even bring the batteries with you when you go to pick it up and drive it. |
The current bid is ~$5,000.
Poking around the Internet, checking the various EV group sites, I find complete, usually owner built cars in the $15-30K range. What would be a "good" price on this commercially built car, on the surface ready to drive, save the batteries?. Some $4k would also be needed for a battery management system, battery box heaters -- ~$2.5K of that to add not strictly necessary AC. |
Holy yogurt! It's about an hours drive from me in Hingham MA; very near where I was commuting to. Hmmm. Hmmm.
[I doubt that I will be bidding on it. But if someone wanted me to go and look at it and take some pictures, I might be able to do that.] |
Heaters & insulation are relatively simple, inexpensive add-on as well. Again, if you were a tinkerer (to get it up and running) and this car would meet your needs, it would be a great EV to have. |
Hi,
Okay, I am interested in this car, and I read the seller's answer to the question about the batteries needed: they are 12v 60Ah gel lead-acid deep-cycle, of a specific size (which he does not specify). Any guesstimates on the cost and a source for these? I'm wondering if Azure Dynamics can supply them? I've asked whether this car is the 4-seat model (it seems to have a back seat), and if it is, it is rated as having a 60 mile range. I also asked if it uses an actual automatic transmission, and if so how many speeds is it. Or, is it a reduction gear, and does it have a reverse? I'm hoping to hear back from the seller about going down and seeing the car first hand, and meeting him in person. |
1 Attachment(s)
In case no one noticed, there is also a Force available in PA:
http://ecomodder.com/forum/attachmen...1&d=1261580176 Geo : Metro:eBay Motors (item 160380990798 end time Nov-30-09 13:31:16 PST) |
Hi,
I have decided against buying this car; for several reasons. I am concerned about safety, and the fact that I am not currently employed, being the two main ones. |
It just sold for $4350 (needs batteries). The first (older) one listed in this thread sold for $4950. |
