Noobie lots to learn lots of questions
Hi there
I live in the Uk and have a interest in building a high mpg car. I have always like this car and when I became interested in building a hypermiler I realised this car had several good points ? http://www.thetrivette.com/HISTORY.HTML Aerodynamic Light Take any engine 3 wheels less road drag etc Currently planning what to use for a engine ? Do I buy a 3 cylinder swift/metro engine ? If so do they all come with a ECU that can be hooked up to a scan gauge ? Or could a Citroen 2cv 602cc engine be better as it is very light , compact and in a 2cv is capable of getting between 45 - 65 mpg as standard. The metro engine maybe is heavier and has lots of emission stuff I don't need [ added complication ] The 2cv is very simple and could maybe improved with better exhaust and carburation but it will be harder to get mpg figures from it. anyway I will end my ramblings now as I have some drawings to do ! regards Paul |
Welcome to the site stormbird. I would definitly use a smaller engine. Maybe a motorcycle engine? You could even go smaller than 600ccs. That would be plenty of power for a lightweight three wheeled vehicle.
Daox
The 2cv has several good things going for it , I can use the chassis only slightly modified for about 80% of the car , it is compact and easy to work on [ simple !]. There is a manual here about building trikes and does recommend car engines over bike engines if possible :- http://www.btinternet.com/~jhpart/books.htm I hope to build it as a trike first and then clothe it. Paul |
