Not another newbie...aww man...
Hey folks,
I'm new. Please excuse my newbie posts for a little while at least. I am the father of four boys and as such drive a 2008 Dodge Grand Caravan SXT whenever we all need to go anywhere together. This is going to be the initial target of my eco mods. |
My daily driver is a 2001 Buick LeSabre that I inherited years ago. Not the best on gas mileage, but gets better than 30 on the hwy (17 - 19 city) unmodified and is ridiculously comfortable.
And my toy is a '73 Porsche 914 that I originally picked up to turn into an EV, but am waiting on batteries to get cheaper.
(I'm padding my posts here to get to 5... :)) |
Cool.
Well, the basics first. Tuneup, change the fluids, get the tires up to the sidewall imprint max pressure. In EcoModding Central, get started reading the Sticky "Master list of 65+ proven mods... ". It will tell you more than I certainly can. Use the thinnest engine oil suggested/recommended by your owners manual, as long as that grade doesn't burn or leak out of the engine. Exactly which mods will help you the most depends partially on your driving type. If driving many short hops to deliver and retrieve youngsters, you could benefit from getting the engine warmed up quickly and then taking maximum advantage of that warmed up state. When you need tires, make an effort to get low rolling resistance tires. Consider a belly pan. Not a small or quick project but I think a minivan's aero is mostly pre-determined in other areas. Often the underside is an aerodynamic nightmare that can be improved, even if your creation is not perfect. |
pnambic -
Welcome to EM! I want drivetrain diversity, so it will be neat to see what you can get with your Caravan and LeSabre. The idea of owning a Buick LeSabre super-comfy-vacation-trip machine is intriguing. CarloSW2 |
Im intersted to see what you can do with the van.
