Not very good gas mileage, please help
My 2005 Civic VTEC with an automatic transmission is, for some reason not getting as good of gas mileage as it should. I have done a few things to it in part to improve mileage. It has a power steering delete, AC removed temporarily, new timing belt, minor weight reduction, almost new LRR tires filled to 40 PSI on alloy rims, all LED lighting except interior and reverse lights which will get swapped too, recently I fully rebuilt the engine, high flow header, cat and muffler, D16Y8 intake manifold and fuel injectors, custom air intake system, and a couple other minor things. It only gets around 26-28 MPG. I checked all the sensors and it has a new thermostat. It runs very well, but not very efficiently. The only things that I can think of that might be contributing is a crack in the exhaust header, the EVAP purge valve is stuck closed and it is missing the front wheel well liners, but I will install those soon. Any ideas? If you have any questions or things to check, please let me know. Thanks a lot.
UPDATE: The last 2 times I filled the tank after I installed the wheel well liners and JB Welded the crack in the header I got 31.5 and 33.7 MPG on my last 2 fill ups. The first tank was a decent amount city driving, and the second tank was more highway driving. I might be able to get the mileage even higher if I fix the EVAP purge solenoid, fix the problem with the o2 sensor intermittently going dead and possibly reconnect the EGR, although I do not want to cause more carbon buildup in the intake and cylinders by pulling in dirty exhaust, so I probably won't reconnect the EGR unless I can keep the carbon out of the intake somehow. |
City driving? Highway driving? normal automatic or CVT?
You're about right for mostly city driving in a normal automatic trans. |
Welcome to the forum. It's possible that rebuilding your engine is part of your problem mileage wise. If you tightened everything up in the rebuild, it may take some time to break in again, just like in a new car. Also, the cracked header may be effecting the O2 sensor readings. May not be enough to through a code but enough to reduce mileage. Just brainstorming with you. Did your mileage drop after all that you've done or is the quest for better mileage something recent?
Automatics are harder in general to hypermile due to the limited driving techniques at your disposal. I found it worse when I did a lot of in town driving. Wondering if your commute might be fighting against you. |
Maybe a bearing ?
Handbrake ? If not something like that, an o2 sensor that is bad would drag down fuel economy. So replacing that could help. |
Details about your driving patterns? How fast do you drive? Any traffic? Head winds? Do you have any fuel economy instrumentation?
Food for thought, I get about 50mpg at 80mph, and 100mpg at 55mph. |
Filters too. Check fuel and air filters for clogging. ...but I like the O2 sensor for air infiltration from that crack screwing with the ECU.
Maintain and repair the most obvious first... then move on to less obvious... you'll find it. |
oh, biggest "simple" killer of fuel efficiency is a inlet manifold leak, possibly around the injectors or throttle-body somewhere. This would explain everything. Spray with hydrocarbon-spray till you find a vacuum-leak.
When you get it figured out, come back and tell us what did it. We'll be interested. Better yet, become a regular on the forum. You are welcome here, of course. You seem to know your car really well, too. I had no idea they moved the fuel filter into the tank after the 6th generation. That just makes things unnecessarily hard to check.
