o2 sensor o2?
Has anyone tried increase the atmospheric O2 concentration at the O2 sensor by using tank or electrolysis?
i have not tried that one, never heard of it before either.
can you explain it a bit further, whats the purpose, what is it supposed to do ... |
Are you talking about doing this in the exhaust stream, or on the cold side of the o2 sensor?
A few people have put tin foil around their o2 sensor, on the outside of it, because it's using the o2 in the outside air as a reference point, if you restrict that air flow it will make the engine run leaner and a difficult to control manner. |
