Old 07-08-2008, 02:41 PM   #1 (permalink)
Turtle 1990 Geo Metro Idle test
Several years ago- before the hybrids showed up I did at test on my Geo to see what MPG it clocked up in idle(yep like sitting at a stop light)...of course these days a Prius would be off.
My test did not have the benefit of a scangauge(which I now have)-but I filled the gas up to the top of the neck where I could see it was in the same spot, before and after the test.
Did you know that a Geo will go between 12-18 mph in 5th gear without lugging??And my 1990 did not have the advantage of electronic vacuum advance.
The test consisted of my riding my road bicycle route to Fort Christmas Florida and back- 28 miles.
Mpg was 99.4 Mpg.
Which could translate to 4 minutes at the light stopped equals 1 mile down the road.
Has anyone ever compared the exhaust pollution at idle to the travelling pollution??
My 1990 GEO is now retired, but I have a 3 cylinder 2000 Chev GEO 5 speed to replace it...it weighs several hundred pound more, I hope to put it on a diet using the wonders of this website.
I appreciate your comments,
Cinaroh
ps- my scangauge just showed up so it will be in my 2000 Geo shortly.
Old 07-08-2008, 02:51 PM   #2 (permalink)
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
When I was watching my car get it's sniffer test for the state inspection, idle air pollution was a fair amount less then at either of the two testing speeds on the rolling dyno they do here in TX. Idling at 600-700 rpm or so, vs. driving at 1700-2000 rpm for it's test speeds (I can't remember, but I want to say low speed test is at 15 mph, and high speed is 25 mph).
I don't have my state inspection sheet with me, it has all the polution data.
The old dragracer rule I once heard "Worry about the ounces, and you'll loose pounds", or something to that extent
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 07-08-2008, 10:15 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I "lug" my 3 cylinder around in 5th gear without hurting or pinging the engine all the time. I am usually in 5th gear at around 35 MPH when I am easy accelerating on my route to work. I also go the speed limit of 55 MPH at all times and my mileage I am getting from my 1998 is very impressive.
GeoMetroforum.com - got mpg?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Need Geo Metro information.. Chris D. Off-Topic Tech 5 01-23-2013 05:28 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 10:07 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 09:54 PM
