Go Back   EcoModder Forum > Classifieds > For Sale
Old 10-28-2009, 05:53 PM   #1 (permalink)
3-stage VTEC engine for Civic
My buddy Jerry got in yet another japanese market 3-stage VTEC engine. In short they produced this engine for the 96-98 Civic's in Japan/Europe. It's similar to the VTEC-E but with yet another set of cam lobes and 2nd VTEC solenoid which offers 130HP on the high cam while maintaining the VTEC-E economy. Some members here claim 50mpg with this engine swapped into a Civic.
The motor is located in Bellingham, WA and is priced at
$550.00
The engine is a complete longblock with auto tranny as removed from a car, you may witness a compression test if you like.
It does not have an ECU, so you will need to source one or use a chipped/tuned ECU for proper operation. The engine will run fine on the normal ECU's but only in 12valve mode.
2020imports@gmail.com is his e-mail address.
A majority of his customers are hot rodders so these generally don't sell in that croud, but it's a pretty rare engine that needs a home. No affiliation or kickbacks come my way, just looking to connect someone with a need to someone who has...
Old 10-29-2009, 10:31 AM   #2 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
So tempting, but I just rebuilt a D15Z1 and threw it in my VX over the summer. Plus, getting the correct ECU for that motor is a little tough, but can be done.
Old 10-30-2009, 07:30 PM   #3 (permalink)
That would be the P2J ecu. They are availiable.
With access to my local tuner only minutes away were going to make mine work with a chipped 92-95 ECU.
The integra GSR computer has two points of load/rpm activation-fuel maps- for the intake butterflies and the other obviously the VTEC engagement.
He's confident we can use the "butterfly" signal to engage the 1st stage of VTEC along with the regular signal to kick in the high cam.
Old 10-31-2009, 11:09 AM   #4 (permalink)
That VX guy!
TomO's Avatar
Good thinking, I never thought of using that ECU.
Old 05-25-2010, 10:42 PM   #5 (permalink)
I have this engine running on a obd1 p72 ecu with a hondat s300 ecu, iab is controlled only by rpm with a chipped ecu, with the hondata s300 it can be set by rpm/load/tps just like vtec with fuel/timing adjustment
Old 05-25-2010, 10:49 PM   #6 (permalink)
vtec sends 12volts at 1amp for the solenoid, as where iab is a simple ground in the ecu, so the iab wire should be connected to a relay, the relay has key on 12v to it and the ecu will ground the relay turning it on and thus connecting the needed 12v to the 12-16valve solenoid. I achieve 42mpg on a good tank with ac, 9psi boost to redline here and there, plus 65-75 mph on highway.
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Honda Lean Burn D15B 3-stage VTEC rkcarguy For Sale 12 01-20-2010 01:42 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
