Ontario man pulled 53' semi trailer with a Silverado
1 Attachment(s)
https://i.imgur.com/FBlJ6Gs.png
I feel like there are ways this could have been done correctly. That should include an air system, which they did, but wouldn't they use a bed-mounted fifth-wheel hitch? Would you have called the cops or taken a picture and gotten out of the way? https://www.caranddriver.com/news/a3...-long-trailer/ One does not simply pull a semi trailer with a pin: https://ecomodder.com/forum/attachme...1&d=1576983451 |
That looks way safer than the 5th wheel trailer my dad pulled with something like a 1960 Chevy truck.
My dad cut a semi-circle out of 2 boards so that when they were placed together, would capture the 5th wheel ball between them. Then he bolted the boards to the side rails. The emergency chain was a come along winch cable. Went through a full tank of gas going about 100 miles roundtrip. Ran out about 4 miles from home. |
I am pretty sure that boards are not rated for that.
Probably something similar in size to this, and it would be called a kingpin and not a ball hitch:
https://media.nextechclassifieds.com...5742421_1.jpeg |
Oh well then. That's different!
