Old 08-19-2013, 10:43 AM   #1 (permalink)
Electric Car Builder
Question I need help reading cougar outputs
Hi everybody.
I need some serious help. My EV is nearly finished. It is driving, but I still need to finish the instrumentation.
I purchased my open revolt fully completed, and it works great, but the guy who built it is no longer responding to my emails.
I want to use the output string from the Open ReVolt Controller to read and display the system Voltage, Amperage, Temp, etc... I will be using Arduinos, to process the data and display certain values on LCD screens.
I need to know a few things about the cougar:
1) which pins on the RS232 carry the output serial data?
2) how is the data formatted? (separate lines, comma separated values, etc)
3) what is the frequency of the data? (baud rate, if applicable)
Thanks for you help. You guys are awesome.
Old 08-19-2013, 02:17 PM   #2 (permalink)
So i purchased a Serial to TTL converter for Arduino, and I am just going to assume it will correctly translate the output stream.
I will post my results here when I find out. Maybe it will interest somebody.
Old 08-20-2013, 05:23 AM   #3 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Hello.
These pictures are from schematics and build instructions. Black wire is ground, green is pin 2 and red pin 1. Hope this helps to figure out from where to read data. You might be able to figure data formatting from source code. I have no skill to do it right away but might figure it out eventually when staring at the code long enough. Hehehe.
See serial.c and cougar.c at
Index of /firmware/cougar-v1.11b
Main loop has something serial output related. At the end of the file cougar.c it is.
ID:	13648   Click image for larger version
Old 08-20-2013, 11:23 AM   #4 (permalink)
Ah, so it isn't true RS232 style Data. That will be much easier to deal with, i think.
I will rummage through the code too, and see if I find anything.
Thanks.
Old 08-23-2013, 09:26 AM   #5 (permalink)
apowers's Avatar
Here is a link to a PIC based display. There may be something to help you in that thread.
http://ecomodder.com/forum/showthrea...ler-16132.html
Alvin
