Open Source high power DC-DC converter
Go Williamson Go! Williamson is making an open source DC-DC converter. 14v out, 90amp. That should run just about everything! He's going to post his progress here.
Holy moly! :D
I'll be watching... |
What topology does it use? Dual switch forward? Full bridge? Something else?
I think 90A is a bit overkill for a well-designed EV, unless you're going to run something like the A/C. Even then, it's better to design it to directly run those from the main pack. I'm working on a power supply that converts 340v DC (voltage doubled 120v AC) to 12-15v DC at up to 35A for IT use. I'm planning for a minimum of 80% efficiency at half load. The standby power usage is currently only 1/8w and I'm planning for less than 1w idle power usage. It will have a control interface that will allow a BMS/PMS (Battery/Power Management System) to control its output voltage and current limit as well as turn it on and off and monitor temperature and output current. (It will default to outputting about 14.4v at maximum current limit if the control connector is disconnected.) It could be used in an EV if the nominal pack voltage is 240-288v. By changing the transformer turn ratio and using different primary inverter components, it can be redesigned for just about any practical input voltage. |
I am planing on running 90 TS 100ah cells for a nominal voltage of 3.2V x 90 = 288VDC. This will rise to 3.8V per cell when charging, this will be 342VDC. Will this cause a problem for the converter?? I look forward to seeing some plans!! -Adam |
A forward converter would be a good simple option as its unlikely ever to need to exceed the max 50% duty limitation of that design.
Looking forward to seeing the OpenSource DC-DC become available and integrated into the open BMS, charger, display and controller. Great work to all those involved.
Has anyone considered running the display for all things EV on a android device?
