Open windows (04 Dakota pickup - air flows IN through rear window - extra drag?)
In my Baby Truck I usually drive with the driver's window and back sliding window open because I have no AC and I hate the heat. I notice that the wind doesn't flow into the truck through the drivers window but from the back window. I'm just wondering what kind of drag this causes if any. Any ideas?
Yes that is what I would assume it's doing, but is that better than coming in the driver's window and slamming the inside off the truck then going out?
As always, pick a day with moderate temps (or late at night), and run a mileage test with and without the windows open. Then you can answer the question for all of us!
from the back
I just did 1,379 miles like this and the mpg was good enough that I don't think it's an issue.I suspect that the drag is offset by not operating the AC compressor. |
Thank you Aerohead. I can feel a little bitbetter driving now =D. The clutch on my AC was out when I bought the truck and I don't feel like paying 300 bucks for a new one.
clutch
