Optima Red top = Garbage
Returned my 4th one to advance auto parts on Saturday in 18 months.
All of them end up with a shorted cell. err As an experiment I left the last one on my back porch for 6 weeks not connected to anything, tried to charge it and discovered a shorted cell. As another experiment I've been running my Supra (Golf has a conventional battery) on a walmart lawn and garden battery for 2 months. It hasn't had an issue yet. So be aware. |
I've never seen reports of that many failed batteries from Optima - and I used to sell them at Sears.
You should have your charging system checked, honestly. There might be a problem w/ the Voltage regulator or Alternator, or even a bad ground that is charging the batteries higher than it should be... they can't take more than 15V, and they're only rated for 14.6 cVDC without failing. |
Then again, maybe you should get your money back from them, since I just noticed you didn't even use the last one, and it was still shorted, then go to another store that sells them and make sure you didn't just get into a defective batch.
The Red's aren't the most popular batteries compared to many other types, and you could possibly have gotten a complete batch of batteries to fail on you if you kept going with it, due to the relative lack of sales activity compared to other types of standard batteries. If, in fact, you got into a bad batch, you might find a good one at another dealer, and you'll still be covered under warranty. |
I'm an ASE certified auto parts specialist, and an engineer. I have to agree with the Christ. Optima != garbage. I've seen lots of cases of Optimae testing bad, then being thrown on the slow-charger over night, and subsequently testing good and working fine.
That said, I don't recommend the Optima to most people. AGM batteries are really neat technology, but the vast majority of people who buy them, don't really benefit from those advantages (nonspillable, vibration resistant, the yellow-top are deep-cycleable). One downside of the Optima is that fast-charging it kills it. The other downside is it's twice the price of a conventional battery. Regarding the lawn & garden battery: That's probably rated for 300CCA or so. It'll work fine for now, but I bet it'll be unable to start the car next winter. Undersized batteries don't last, for whatever reasons. |
Also, you can test the bad batch theory by checking the date code on the batteries. I'm willing to bet your local Advance doesn't stock more than one or two of them, so I'm pretty sure your batteries came off of different shipments.
Does it get cold in Louisiana? I don't think "winter" is an issue LOL.
If you do end up having a problem with starting in the winter (whatever you call it) you can always link another L/G battery in parallel w/ the one you have... this will double the cranking amp output for you, while maintaining 12V, and should start your car just fine. |
Honestly 2 have never been in the car. Honestly the Lawn and Garden battery has not failed yet. This is my 3rd optima red top the the first 2 lasted until I sold the cars . I'm under the impression that they *were* great. |
Wish I had read this before my last response . . . . I should have mentioned before my discussion with the manager of Advance Auto parts here in town. They are returning them like mad (don't bother checking them) but are not allowed to return them for money/ credit after 90 days. |
These guys Charging an Optima or AGM Battery : Batteries Are Us recommend charging at a minimum of 100 amps. No Idea who is right . . . . . Quote:
Just ran across these 2 on their page. News, Events, FAQ News, Events, FAQ Quote:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
