Orbis Wheel
https://orbisdriven.com/
Why is this in the unicorn corral? Seems like a neat invention and a logical extension of the proven tech Edison2 came up with.
It makes claims that can't possibly be true, such as "weighs no more than a conventional wheel". I'm not thrilled that there's a gear around the inside perimeter of the wheel either. Seems like debris would constantly be crunched in there.
The Edison in-wheel suspension was not a good idea. It adds to unsprung weight needlessly and compromises the length of travel. Conventional suspension is pretty good. It didn't really solve any problems. That's the whole thing, a new product must solve a problem better than any other existing products. |
I'd be more impressed if they had the wheel on both ends of the car. It appears the Civic is frontwheel drive with these tagged on the back, but the exploded diagram shows an electric motor. But no brake? [shrug] Then there's the $10K price tag. |
I'm not sure where this extra unsprung weight you're talking about comes into it? I see a coilover, a couple arms, a brake caliper/rotor, and a hub, all cleverly packaged, but the same stuff as in any current car. But you certainly have a point about somewhat limited travel. https://www.elioowners.com/attachmen...ion-jpg.16965/ That's one of the drive wheels. That reduction box/portal axle thing does look to add some unsprung mass. But IIRC the reason for it was to tuck the axle aerodynamically up with the main suspension support spar above. Throw the drive axle straight into the back of the hub there, and I'm still not seeing the reduction in unsprung weight with something like a Honda civic: https://d2t1xqejof9utc.cloudfront.ne...d/original.jpg Orbis... yeah, they're adding unsprung weight, but they seem to weigh about half (35lbs) of what other hub motors weigh. Seems like a win and pretty non-unicorn to me. |
Maybe it doesn't add much weight, but the point that it reduces travel remains. If this were a better way to do suspension, they'd already be using it.
...and I was misremembering their implementation of in wheel suspension thinking it was something more along these lines: http://www.mogowheelchairs.com.au/as...l/SOFT-001.png |
They showed up at SEMA with a modified new Type R Civic. Weighed parts on camera, discussed Motor Trend test results:
https://m.youtube.com/watch?v=iQ4lTPVR3qc Here is the motor Trend article: https://www.motortrend.com/cars/hond...-r-awd-review/ "These two permanent-magnet AC electric motors, borrowed directly from a Zero S ZF13.0 electric motorcycle, add about 50 hp and 70 lb-ft of torque to each rear wheel. They spin the wheel rims via a fixed 6.2:1 gear ratio. They're powered by Zero Motorcycle batteries with a total pack capacity of 13.3 kW-hrs. Removing the back seat and cargo area floor and mounting these batteries and the controller that makes it all work adds about 180 pounds to the curb weight of the original Civic Type R." |
Ah, so the no weight gain claim is based on the ridiculously light weight caliper and rotor they use offsetting the extra motor with. Makes more sense.
Also, the hubcap is apparently solid or optionally lexan backed and seals the front of the wheel, but that still doesn't explain how grime won't get in there from the back. Those unlubricated gears seem problematic... at least they're straight-cut, but I would assume they're going to be wear parts that require fairly frequent replacement. Fine for a track car, but maybe not so much a daily. |
Another video about the Orbis Wheel, complete with demonstrations. This one is by the YouTuber HondaProJason. It includes discussion of braking and other capacities that I haven't seen in the other discussions by Motor Trend and at SEMA. There is some repetition of marketing claims as well, however.
https://m.youtube.com/watch?v=ocYd0I1cJH4 |
The rollers ride directly on the rim. What happens when one or more of them lock up from getting wet/dirty? How much does it cost to retrofit or even repair/replace? And those tires look very out of round.
It would be cool to get this stuff to a fully working/durable stage, but I see too many weak areas in the engineering. Bearing surfaces worry me in this application because there is no way to keep them clean/lubed. This is screaming "prototype" to me so loudly I can hardly hear anything else. |
I was interested in this system but only having a 19" wheel is a deal breaker for me. It would also be impossible to rotate the tires with this setup. This would be good for a track car though. A much better setup would not involve the wheels, so it is more practical for normal drivers.
Funny how their slogan is "The Green New Wheel". At least their marketing has some real numbers, and is technically feasible, unlike the Green New Deal.
Yeah! Every thread should have politics in it!
*Skip* |
I appreciated it too.
Not sure why people interpret it as a political statement, as I try to avoid politics as much as possible. I saw an abstract connection between this product, which I've been critical of, and GND, which I've also been critical of. Then their own advertising appropriated the slogan. Clever. When I criticize something, it's because the idea has problems (or my own understanding has problems), not because it's associated with a particular political party. I don't even know what party The Green New Deal is most commonly associated with because I don't follow politics. Socialist party? Green party? I dunno. |
[aerohead touched on this with his book review in the Climate Consensus thread.]
I criticize things because I am a sad and strange little man.
I criticize things because I can think critically, and expect others can too. I'm critical, but not too cynical in my estimation, though I have been too cynical in the past.
The climate consensus thread is epic, and should never be locked. People unable to contend with the discussion there aren't forced to visit the thread. It's among the most impactful discussions yet that has informed and shaped my understanding and opinion of climate change, and ongoing discussion is likely to continue this evolution of thought. |
does anyone have any more info on this?
Seems like a great idea to retro-fit electric assistance to any FWD vehicle. Where did the pricing comment come from (page 1) saying this was $10k? I can't find any info on the web with pricing? FWIW i'm also "following" orbis on face book and i've asked if there is any more news since the flurry of info after SEMA show. ************ edit to add: ***************** ok so i got a response from their FB page, yes $10k for two wheels, all production fully allocated for 2019 so if you want anything it'll be next year. This is a great concept, but i'm out - as a mod to improve mpg it'd take a very long time to recoup your 10k investment.. shame as i really like this approach. |
Here is an email that I got from the company. It is just a generic copy and paste response: Thank you for your email and interest in ORBIS and our Ring-Drive system. We are excited to bring the technology to the retail market. Since our “debut” at SEMA last October, we have been engaged by a large commercial entity to develop an integrated AWD platform. As we are a start-up with very limited resources, we have been forced to focus on this project and are temporarily shelving a direct-to-consumer retrofit kit. We hope to offer a “universal” kit for both FWD and RWD vehicles in the next year or so but currently I do not have exact specs or a list of which vehicles it will work with. Currently, however, we are working exclusively with a 19”x 8” wheel, if that helps. As soon as we move closer towards bringing the technology to market, we will be able to answer more specific questions on an individual basis, including which vehicles and which markets we will be able to serve. In addition, as we establish manufacturing, we will be looking to engage with potential licensing and distribution partners. I will be sure to keep your email address and notify you in advance of a public announcement, whenever that should occur. Thank you for your interest and understanding. Best regards, Peter |
ok, similar to my response but a bit more info in mine (today) i think:
"ORBIS Driven Hi Rob, thanks for your interest in Orbis wheels. The wheels start at US$9,995 for two. Our manufacturing capacity for 2019 is fully allocated, which is why we are not accepting new orders. But we'd still love to contact you when we're ready to take your order, so if you are interested, please complete our form here: https://orbisdriven.com/contact/ And please do like our page, if you haven't done so already. Thanks again." |
If i manage 70mpg now, and the orbis bumped me up to say 80mpg, then my basic calc looks like it would save me about £1 per trip, so i'd need 10,000 trips to break even.. so ~50 years :) Even if my maths is wrong and the saving is double that ^ it'd still take 25 yrs to break even, by which time the car would have over half a million miles. |
The way I look at it is that it will cost only 10k to convert your car to a hybrid. New hybrids are much more than that. This is very cool, and worth it to me if it is reliable and not overly cumbersome to rotate tires and things. A difference is that I am looking into doing this to an older vehicle that I will acquire instead of a new one. |
Rich Benoit (Rich Rebuilds) is putting one of the same [brand] motors in a Model A lowboy roadster. Clutchless, on a three-speed (prolly 1939 Ford (last year of the floor shift)).
I could see a pure EV, with 100hp driving the rear wheels. Here's an example with a golfcart motor and lead acid batteries: https://ecomodder.com/forum/member-f...ectric-t-2.jpg You could put thin fenders and running boards on that and hide a Tesla or Rav4 battery pack. Frunk 'n trunk. |
Yep, i also like the idea of using this tech to electrify a classic.
My "other" vehicle is a 78 vw westfalia - great vehicle but a really old tech aircooled engine with only 70bhp from the factory and lousy mpg. Adding this sort of bolt on tech would be a game-changer for that vehicle (although as it's already RWD it may not be as easy to integrate?) BTW - i checked with Orbis - the 10k cost is not the full investment you need to make - that's just for the bolt on wheels /motor/brake etc. . You'd still need to buy a battery system on top. @taylor95 - ok, if i say, got ~50 mile range of of this, so i save half my fuel cost on my commute, might add up to almost £1k per year.. still would take more than 10 years to break even :( |
An EV with this technology would be cool. You would need to figure out the computer though.
Wow, that does not include batteries? That's a major expense. Hopefully the price goes down in the next five years which is when I would be wanting to buy this. 10-12 years would be a great payoff time, depending on how long you plan on keeping the vehicle. That is around the same time that solar panels on a home would pay off. |
Figure $2,000 for some automotive salvage pack, $1,000 for a decent 3ph A/C controller used
I could not find all of the numbers for an F-150, so I am just quoting this: Quote:
I do not know for what weight vehicle the 12 HP figure would be accurate, but let's take my 1,075 kg and 115-pound HX, remove the back seat, drop in a 540 kg Tesla battery, and now I have a 1,615 kg 225 HP 2-seater that needs a suspension upgrade. Now I need 18 HP at 60 MPH and... what is the point of a car like this? To need to fill up and charge, which I really do not think you would want to do at the same time? |
I actually have a Silverado in mind, which is pretty similar in terms of weight and cd. It would be used for towing occasionally as well as being a daily. Having the orbis wheels would be great on this--as long as charging is not a requirement. In my experience, increasing horsepower will increase mpg as long as you don't drive the vehicle aggressively in most applications. |
It needs to be powered somehow. If they developed a Mr. Fusion that is a much bigger deal than this.
Why can't the engine charge the batteries? Isn't that how a prius works?
A standard alternator would be absolutely inadequate. If Orbis Wheels worked, they should be able to provide regenerative braking, but you would need a far more powerful alternator to charge the battery the rest of the time, and the Toyota system uses the "alternators" as motors, too. |
Orbis Wheel updates
The last post in this thread is almost two years old. At the time, it looked like the company had gone dark because they had suddenly pulled the product for new orders.
But they're still here, it seems, with a website updated this year and a San Francisco Bay Area address (Mill Valley, CA): https://orbisdriven.com And a video with clips of more recent testing is on YouTube (new road testing/demo video starts at 3:27 and runs for about a minute and a half): https://www.youtube.com/watch?v=hEpP5lmnz8Q Still, given their claims... their youtube channel is oddly quiet: https://www.youtube.com/channel/UCFO...TLf1h5Uzc9YCAw Seems the pandemic halted their wheel development and shifted them to COVID mask innovation attempts. |
Sorry, this sounds like the flying car.....something of a novelty but completely useless. They tout less unsprung weight and then add 31 lbs to each wheel! All the moving parts and failure points make me cringe. A simple bearing is much simpler and is not prone to failure from dust, rocks, ice, snow, etc... How fast do those little idler wheels turn??? Holy crap. 4 watts my foot. Friction is proportional to rpm in a rotating assembly. I will happily stick with a central spindle and bearing.
:confused: |
