EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   Oxygen generator on cooled EGR only inake? (https://ecomodder.com/forum/showthread.php/oxygen-generator-cooled-egr-only-inake-39131.html)
Isaac Zachary 02-17-2021 01:00 PM
I have no idea if this would ever work nor can I seem to find anyone else that's even so much as thought of the idea, much less tried it.
Why
I think I'll explain the why first. If you can take all the nitrogen out of the intake charge and replace it with carbon dioxide but still have it mixed with about 20% oxygen then the formation of nitrogen oxides should be theoretically eliminated. With no NOx then you can run as lean as you want, beneficial to both diesel and gasoline engine efficiencies. You also can run as high of a combustion temperature as the engine and fuel can handle, which can also increase efficiency.
A side benefit is that we will be getting free water with this system which could be used for water injection, perhaps so that you could run higher compression ratios without detonation or so that you could run stoichiometric AFR's at high load.
A possible side benefit is that there would be the possibility of running higher concentrations of oxygen than 20%. I'm not sure if that would be practical, but from a theoretical standpoint ICE's should be more efficient with higher concentrations of oxygen since the combustion temperatures would be higher.
To sum it up, theoretically you should get an ultra-low emissions engine that has the potential of getting better fuel mileage.
How it's supposed to work
Take an engine and loop the exhaust through a cooler and right back into the intake. Then take a high purity oxygen generator (probably of the Vacuum Pressure Swing Adsorption variety) and fit that on the vehicle somehow and feed the oxygen into the intake. We may also want to prefill the exhaust/intake loop with CO2 before starting just to remove any nitrogen from the system.
How this theoretical engine works is that we start off with CO2 and some water vapor in the system headed towards the intake. The oxygen generator separates the NOx out of the air and introduces the O2 into that CO2 in the intake. Fuel is added any way seen fit (port injection, TBI, carburetor, direct injection, etc.).
During the combustion process we should get about everything we normally get emissionswise except NOx. Since the engine can run leaner with no emissions dependency for EGR we should get less CO, HC and PM emissions even on diesels. Not only that, but a lot of the exhaust (75-80%?) will be cooled and funneled right back into the engine to give it another chance to burn. The remaining exhaust can be run through a catalytic converter that should have an easy time burning up anything left over for a super-ultra-very-very-low emissions ICE. The catalytic converter could also be made much cheaper or perhaps even eliminated all together and still achieve these ultra-low emissions.
Of course cooling the exhaust means we'll get a lot of liquid water which may be used in water injection. Since water has an octane effect this could lead to some very high compression rations.
Problems
Well of course cost is a major one. Complexity another.
There's also the question of how efficient the oxygen concentrator will need to be since there exists the potential for it to sap way too much power from the engine just to provide enough oxygen to run. Whether or not the efficiency benefits from not having to deal with NOx emissions would be enough to overcome the power needed to run the oxygen generator would be key to whether this would make for better fuel mileage or not.
Also it will need a lot more cooling since we'll have to be cooling a large amount of the exhaust back down to near ambient. Which also means there can be the problem of not being able to cool the exhaust enough which could cause detonation problems. We could could try to compensate by holding back on the amount of oxygen being used but that would defeat the purpose of this setup.
Possible application
Since the oxygen generator will take up a lot of space this might work best on a very small engine so that the oxygen generator can be made as small as possible too. I'm thinking that this might be good as a range-extending engine on a BEVx type vehicle, or at least some sort of hybrid that has enough umph! from the electric (or hydraulic) drive train so that the engine can be made quite small.
Thanks!
Anyhow, thanks for reading my crazy idea.
RustyLugNut 02-18-2021 01:52 AM
Your idea is not that crazy.
A team for the Auto X-Prize was planning to run an oxygen only combustion engine to eliminate pretty much all the emissions and to increase combustion efficiency dramatically.
It's one thing to test with bottled oxygen. It's another to run a trunk full of adsorption oxygen concentrators. Also, the use of steam injection to moderate temperatures resulted in a very large condenser otherwise miles per gallon of . . . water became a thing to watch.
cRiPpLe_rOoStEr 02-18-2021 10:00 PM
I guess you have seen something about HHO systems before. That's too energy-intensive for little to no actual benefit.
RustyLugNut 02-18-2021 10:46 PM
In a parallel to this discussion.
HHO (oxygen and hydrogen from electrolysis) does have benefit to fuel efficiency in the order of 5%. That sounds familiar? The paper quoted in the original post of the ozone question gave a similar gain in it's result. What is assumed in the electrolysis production of the HHO being pure oxygen is incorrect. It is not all O2. A percentage of the oxygen is in the form of O3. If specific pollutants are introduced into the electrolyte, even more ozone is produced during electrolysis. It is this ozone that has the greatest affect on combustion reactivity. Hydrogen does form radicals of its own but it is greatly aided by the presence of the ozone.
some_other_dave 02-18-2021 11:11 PM
Umm, how do you propose to remove all nitrogen from the air going into the engine? N2 is roughly 70% of what goes into the engine to start with. Even after adding hydrocarbons and then combusting them, you'll still have around 70% of it is nitrogen of one form or another, mostly N2.
Just routing exhaust gas (cooled or not) into the intake won't substantially change the amount of N2 going through the system, since you'll be displacing 70% N2 air with 70% N2 exhaust.
If you could eliminate NOx, that would enable lean mixtures for good fuel economy. But it's hard to see how this would accomplish it.
-soD
RustyLugNut 02-18-2021 11:49 PM
Medical oxygen concentrators can remove the bulk of the nitrogen.
-soD
Once you have reduced the nitrogen concentration down to the low single digits, the formation of NOx becomes proportionally minuscule. The heat becomes a problem as all hydrocarbon fuels burn rapidly in near pure oxygen. Brake specific fuel consumption (BSFC) is reduced via ignition near the theoretical optimum of top-dead-center (TDC).
The problem is removing the nitrogen gas. Even a small engine needs a volume of air in the order of hundreds of liters per minute at cruising speeds. The use of adsorption oxygen concentrators limits the volume through-put of working gas.
The elevated heat of combustion also becomes a problem. Ceramic coatings or parts do help to a degree, but the temperatures can approach that of an acetylene torch!
One solution is to provide a replacement to the N2 gas that makes up 79% of our air. This gas provides a buffering for the flame reaction as well as providing mass to create pressure. However, at 2300 degrees centigrade, nitrogen becomes reactive though much less so than hydrocarbons - it does steal some oxygen to form NOx. But what if you could use a far less reactive gas than nitrogen?
That is where water injection comes in. A small volume of water, directly injected into the combustion chamber pre-ignition point will flash into a large volume of steam providing the buffering gas and the pressure producing gas.
Then you have to design for an on-board condenser to try to re-use some of the water.
And now you have complexity heaped on complexity.
It is far easier to run the engine on outside air, limit combustion temperatures by running in the ultra-lean regime and feeding a small amount of ozone into the fuel/air mixture to reduce the co-efficient of variability for combustion to reduce or eliminate your un-burned HCs.
Isaac Zachary 02-18-2021 11:52 PM
Electrolysis is way too energy-intensive using way more energy than could be produced from it. Oxygen absorption from air should require less energy, but can still be quite energy-intensive.
Of course oxygen could be produced from electrolysis or absorption or some other means off the car from some energy neutral source (solar, wind, hydro) and bottled and then put on the car. But it would be better to use that energy in a BEV instead of bottling oxygen.
-soD
If you first charge the intake/exhaust circuit with pure CO2 to start with then only add oxygen and fuel it should theoretically not have any nitrogen in it ever again. Even if you don't with every cycle it should add more and more CO2 which will eventually displace all the nitrogen until there isn't any.
Isaac Zachary 02-18-2021 11:57 PM
One solution is to provide a replacement to the N2 gas that makes up 79% of our air...
I didn't think about using purely water injection, but that might work.
My original idea is to cool nearly all the exhaust and reroute that back into the intake and use some of the condensated water from it for some water injection.
cRiPpLe_rOoStEr 02-19-2021 06:05 PM
I am usually more favorable to water injection anyway.
Isaac Zachary 02-28-2021 08:07 PM
I think I just debunked my own myth.
The specific heat rato for air hovers around 1.4, whereas CO2 is around 1.28. doing some simple math points to needing a much higher compression ratio to get the same efficiency. For an example, to get the same thermodynamic efficiency as an air fed ICE with an 11:1 CR we'd need over a 30:1 CR to get the same efficiency in a CO2 fed ICE. Water vapor also doesn't help much with it's 1.3 specific heat ratio. The only thing I haven't factored in is if there'd be an efficiency benefit to running nearly as much liquid water injection as we want since lots of water condensation would be available in this theoretical engine.
Helium would be a great working fluid in such an engine with it's 1.5 specific heat ratio. The problem is now we'd have to very efficiently separate the water and CO2 out of the helium in order to make it work as an ICE.
So as it stands now, such an engine would be very inefficiency and cause a lot of CO2 emissions in an effort to remove NOx emissions.
cRiPpLe_rOoStEr 02-28-2021 09:04 PM
Why would anyone be willing to add more COČ than what an EGR already does?
rmay635703 02-28-2021 10:45 PM
-soD
It is possible to separate polar/magnetic/charged substances in air from non polar ones with a charged stack of sorts. (Albeit not 100% effective)
One would need to question if the power draw to divide CO, CO2 and NOx (along with reactive compounds and h2o from the remaining exhaust would be excessive, ignoring the obvious cost and weight of equipment and potential to clog it with soot. The “polar” compounds could then be reintroduced to the intake stream.
Without a way to separate CO2 from the rest you would choke out the engine
Being polar and charged there may be a means to separate the NOx from uncharged materials like CO2, would have to think about it, NOx should be attracted more to a HV charged plate than CO2, not sure how that could be leveraged effectively.
Isaac Zachary 02-28-2021 11:32 PM
My idea was to completely replace nitrogen based air with CO2 in order to completely eliminate NOx emissions.
The idea goes like this.
  1. Feed CO2 (and water vapor) into the intake.
  2. Add oxygen and fuel. (The hard part is getting pure oxygen efficiently to make up about 20% of the mix)
  3. Burn in a traditional gasoline or diesel style combustion cycle.
  4. Take exhaust and cool it, remove liquid water.
  5. Feed cooled exhaust (now mostly CO2 and water vapor) back into the intake for an unlimited supply of CO2.
The theoretical result being able to run as high CR, lean bien, timing advance, etc, as possible without having to worry about NOx emissions.
rmay635703 03-01-2021 06:18 AM
High levels of oxygen can cause otherwise inflammable materials to spontaneously ignite.
CO2 chokes (retards) the flame in relatively small amounts , the two together would ???
There would need to be some happy medium
In effect you are building a rocket or welder the two gases are moderately expensive and onboard production would be $$$ and heavy, likely power intensive as welll.
That said because people are considered too incompetent to fill a water bottle on a car engineers are working on recovering water from exhaust to direct inject at various points during combustion to improve fuel economy and emissions.
https://journals.sagepub.com/doi/abs...68087420933124
https://www.greencarcongress.com/201...-20101015.html
Isaac Zachary 03-01-2021 11:57 AM
I think a lot aren't getting my idea.
Air is about 80% nitrogen and 20% oxygen.
The goal here would be to make an system that supplies 80% CO2 and 20% O2. The CO2 is an inert gas, just as nitrogen is an inert gas. The goal is NOT to make a highly oxygen enriched intake charge. The goal is NOT to make an extremely low oxygen level intake charge. Just keep it at 20% along with 80% inert gases like CO2.
CO2 is not hard to produce in an internal combustion engine. It's free. It's the product of burning hydrocarbons with oxygen. So is water. So the engine will continuously be supplying more than enough CO2 and water than we'll ever need. The main disadvantage is that it would require substantially more cooling.
The O2 would be the hard stuff to produce. O2 air separators are expensive, and require substantial power. But just like anything, this would start out first as an experiment. The question is, could the benefits of not having to deal with NOx outweigh the efficiency penalty of separating O2 out of the air. If that could be established, then the question becomes if cost can be reduced enough to make it feasible for mass production.
cRiPpLe_rOoStEr 03-01-2021 11:57 PM
Would be quite interesting if you could insert the purified OČ inside the cabin and recover the COČ from it.
Considering it would probably require more energy than any increase it could lead the engine output to have, it might be as hard to justify as those HHO generators.
Ecky 05-18-2021 09:12 PM
The immediate issue I see with the practicality of this (and I know I'm late to the thread) is the volume of oxygen.
Peak, a 2.4L engine like as is in my car, pumps 2.4L of air through per revolution. Assuming we want to feed it pure oxygen at 20% of the volume of the air that would normally pass through it (0.48L per revolution), the oxygen generator would need to be able to produce over 200,000L per oxygen per hour.
A quick google search suggests that the typical home oxygen concentrator can produce 3L per minute and uses around 120w. This suggests that, to feed my engine pure oxygen, there would be an electrical cost of 150,000w, or approximately 200HP - the approximate full mechanical output of my engine when using that oxygen, without conversion losses accounted for.
Isaac Zachary 05-18-2021 09:53 PM
Is that a 2 stroke? Only 2 stroke engines pull in approximately their displacement per revolution if naturally aspirated. A 4 stroke only pulls in half. So only 0.24L would be needed per revolution. At 1,000 RPM you'd need 240L per minute. At 5,000RPM you'd need 1,200LPM.
Anyhow, you are still right to a point. A 1,200LPM VSA type industrial oxygen concentrator would still need about 40kW of power to put that much O2 out. Not to mention the huge size and cost. (PSA types would not work. A 1,200LPM PSA O2 concentrator would need about 80kW.)
Ecky 05-18-2021 11:39 PM
4 stroke, of course. It's late and I knew something was up with my math. :D
Copyright ©2000 - 2021, vBulletin Solutions Inc.
