P+G doesn't work on my VW
On my last thre commutes I've Been trying out Pulse n' Glide and it doesn't seem to want to work with my Polo - doing it between 65-55mph (go below 55 and you'll p*ss off the British truck drivers!) the car labours on restart as if its running VERY rich, it doesn't matter if I do a key restart or bump ignite. I have given it the benefit of the doubt even though my fuel guage has been dropping scarily fast.... might just stick to Constant/DWL/Drafting
Quick answer: You are driving to fast for P&G to work. It probably would do just fine from 20-30 mph, :)
Ah.... simple answer! thanks - sadly though truck drivers get pee'd if you drive incosistently around about their limiter speed (56mph) - so i don't want to risk going any slower really.
Fringe benefit though - Aero mods 'should' have more of any effect at the higher speeds I commute at! |
Yep, I would aeromod and stick with dwl on the highway, it is what I do, at least.
Hi rob.
Have you tried p&g with the engine on? You could have fuelling issues when it starts maybe? Could it also be the case that you were too heavy on the throttle during the pulse? I'm just throwing ideas out there so feel free to put me straight! I'm guessing you don't have a scangauge so you have no readout of the engine LOD to pulse properly. Although seat of the pants works well for me..... Best of luck. ollie |
nope no scan guage, I plateau'd back the throttle before cutting the spark, my friend say it might be the simple electronics the dub has in that it knows its moving from the speedo but isn't sensing combusted gas at the lambda so chucks more and more fuel in - then when you restart it runs rich til it settles out again.
If you're just cutting spark you won't see much/any savings. You guess correctly, when the engine loses power the computer tries to compensate, and ends up dumping more fuel into the engine.
Yep and they're on allowed to use two of the three lanes too!
- oh and there is the tacho law too - do you guys in the states have a law about the amount of time a trucker can drive for at anyone time?
Yeah, 8 hours every 24 I think. But I might be wrong about that.
I also once was passed by numerous18 wheelers in a southern US state while going 105mph. I knew the car sounded funny and slowed when I realized how fast I was going. http://forum.ecomodder.com/images/smilies/biggrin.gif |
