Old 05-08-2012, 06:34 PM   #1 (permalink)
pulse and guide question - acceleration and hills
i have a 2010 toyota 4runner V6 (auto) and i'm just starting to try P&G. i have a scangauge in there as well. my main concerns are:
1. accelerating - should i slowly get up to speed i want to go, and then P&G? or go a little faster, still smooth, and then P&G? the truck has a little green eco light, and i usually try to keep the green light on as much as possible, but i'm beginning to think i should just go faster (over 2,000 rpm) and get up to speed and then P&G.
also, when pulsing, how fast should i go? again i try to keep the green light on.
2. can you P&G on hills? i don't have really steep hills, but i do have some longer hills on my daily drive. can you P&G up a hill? let's say i'm trying to get to 50 mph, i gotta get up to speed before gliding, so i gotta get to 55 mph and then glide, and then repeat at 45 mph?
sorry for all the questions, but on my ride to work this morning i got 23.7 by driving like grandma. i tried P&G on my way back and got 24.3. i really think i could have gotten the same by just driving like grandma again to be honest, as i think i normally get better mpg on the way home.
thanks in advance
Old 05-08-2012, 08:31 PM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Scangauge is your friend. Try different driving techniques and find out what gives you the best mileage.
My truck gets better mileage when I step on it and shift at 2500 RPM than if I accelerate like a grandma. I keep up with traffic doing that, so don't annoy others.
Old 05-08-2012, 08:40 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Most cars seem to like an 80% load during acceleration, which is brisk but not jackrabbit. Get up to speed maintaining that load % and then glide. Most people do 10-15mph pulse/glide cycles.
Old 05-08-2012, 08:56 PM   #4 (permalink)
thanks for the replies
yeah i plan to use my scangauge and see what works best. will the scangauge tell me the load percentage? i sometimes was TPS and try to keep it in low 20s while accelerating
Old 05-09-2012, 12:04 AM   #5 (permalink)
Cyborg ECU
It is really load that you want. You will increase throttle slightly as you accelerate in order to maintain load as RPMs climb. I believe ScanGauge has a load reading, but I am not sure how to tell you to find it because I use the UltraGauge.
