EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   P&G freeway tested ABAB +14% FE (https://ecomodder.com/forum/showthread.php/p-g-freeway-tested-abab-14-fe-18325.html)
California98Civic 07-29-2011 10:01 AM
Actually the test was B-A-B-A if A is always supposed to be an “unmodded” run.
PURPOSE
To see if I can do a standard P&G technique I call “GLEN” (Glide, Load, Engine-on, Neutral) on the freeway for significant FE benefits, preferably convincingly beyond possible “noise” of 1-3%. I have a 5.7 mile uphill freeway leg on my regular commute that I cannot route around with practicality or with sufficiently beneficial FE effects to justify the extra distances. Typically, I have scored low/mid 40s on this stretch by driving slower than is legal. Even then, this leg still brings down my averages. If I had a good solution, I could bring my averages up and not risk a ticket for too slow driving.
METHOD
Simple. Same time of day with roughly similar temps day-by-day over a one week period. Wind quite regular (absent) day to day. Drive one day with hypermiling, then the next day without, repeat until I have six runs minimum. The P&G technique used an acceleration arc from 55mph-65mph at 80% load. I then coast down to 55 again, seeking a 60mph average speed during the run. Up the steepest hills, I ranged from 55-60mph in the acceleration arc seeking a 57.5mph average. When doing the straight driving runs, I did my best to hold a steady 60mph, which was very tough in hilly terrain. Climbing the steepest hills I reduced speed to about 57.5. I never used EOC or any other hypermile method, such as driving in the slip-stream.
RESULTS
“A” = with P&G and “B” = without P&G
A – 51.2mpg; ave 59.8mph.*
B – 45.0mpg; 58.8 ave mph.
A – 54.9mpg; ave 57.1mph.
B – 47.7mpg; 58.1mph.
A – 54.5mpg; 59.0mph.
B – 44.9mpg; 58.9mph.
*I forgot the exact mph number at the close of the run but this is close to correct.
“A” averages = 53.53mpg @ 58.63mph
“B” averages = 45.87mpg @ 58.60mph
“A” is 7.66mpg HIGHER than “B” or 14.31% better.
Random confirmation is suggested possibly by a 22 mile run I took the other day on the freeway, using this GLEN P&G method. I got 63.4mpg at nearly 60mph. Under normal conditions a month ago I could have seen maybe 52mpg on that run. Maybe only 49.
skyl4rk 07-29-2011 10:45 AM
Thank you, this is very helpful.
Is the whole course uphill?
What is a typical glide time between pulses?
SentraSE-R 07-29-2011 10:47 AM
Very nice results.
PaleMelanesian 07-29-2011 11:22 AM
Thanks for testing this. I already knew P&G gives great results, but you put it into numbers.
Andyb04 07-29-2011 12:28 PM
Just to clarify, engine is on the whole time, right? Also how did you measure engine load, is it a scangauge function?
Seems like P&G is a lot of work, but if you practice enough it may just become habitual. Thank you for the results!
euromodder 07-29-2011 03:43 PM
Load (LOD) is a standard ScanGauge function.
When referred to on ecomodder, Pulse & Glide is traditionally without the engine running during the glide part.
So California98Civic uses GLEN to differentiate his engine-on technique.
toc 07-29-2011 09:27 PM
Glide, Load, Engine On, Neutral?
Pulse & Glide = Get the car up to speed, and glide to a lower speed, and then accelerate again.
I would Glide with the car in the highest gear, unless I was looking to build momentum, in which case, I would glide in Neutral.
Pulse - I would pulse up to the speed limit.
Can someone explain for me what Glide, Load, Engine On, Neutral is exactly?
How does this work up hill - if you glide uphill, you'll lose momentum and have to get it back - and in many hills that momentum is gone as soon as you get it?
Ahh: Found this: http://ecomodder.com/forum/showthrea...tml#post248966
Still, how does that work on hills exactly?
user removed 07-29-2011 10:53 PM
P&G is currently defined as accelerating at higher engine loads, followed by coasting with the engine turned off. Restart and repeat.
The only difference is he is leaving the engine running instead of shutting it off during the glide.
You could use PNG-on and PNG-off to differentiate. Many AT equipped cars should not be coasted with the engine off as it can damage many transmissions.
Hope that helps you understand.
regards Mech
Vekke 07-30-2011 04:29 AM
“A” is 7.66mph HIGHER than “B” or 14.31% better.
This should be MPG? Anyway nice test. I have observed on my driving that P&G is at least 10% better...
toc 07-30-2011 05:10 AM
I was trying pulse and glide today on the freeway, I'd accelerate to 105kM/hr, and stick it in neutral leaving the engine on (at those speeds I think engine off coasting is disturbing), it doesn't take long for it to drop to 90kM/hr, and then I need to get back up to 105.
That's what I thought a Pulse and glide cycle was - if so, what am I doing wrong as surely, you aren't sitting there on the clutch every 15 seconds engaging gears (or in EOC, starting the engine)?
d0sitmatr 07-30-2011 08:51 AM
its how I PnG, run it up to speed then coast with the car in neutral until Im 5-7 under, rinse repeat.
I did this behind a fairly large truck that was running 5 under, and I think I averaged close to 50% increase, but I did it only because I was in a bad spot when my fuel light came on with no recourse but PnG or run out of fuel ;)
California98Civic 07-30-2011 09:49 AM
Impress your friends and family by saving them from standing on the shoulder! Thanks for all the responses and questions guys. I went through and tried to respond to each below:
“Is the whole course uphill?”
No. It is mostly uphill. Possibly 1.5 of the 5.7 miles are flat with a slightly descending grade. Two are flat/mild and one is a pretty good but short favorable hill. There are three sections of steep hills. In general I am climbing from near sea level to several hundred feet during this 5.7 mile run.
“What is a typical glide time between pulses?”
Sorry, but I have never tried to track that. But it is definitely shorter running uphill than down.
“Just to clarify, engine is on the whole time, right? Also how did you measure engine load, is it a scangauge function?”
The engine is on the whole time because that is safer for me, the car, and everyone at highway speeds. I use an Ultra Gauge, which offers a load reading, but I hear Scangauge does too.
“Ahh: Found this: Introducing "LOG"”
“Still, how does that work on hills exactly?”
I will accelerate uphill and see 25mpg numbers on the Instant MPG readout but even gliding uphill with the engine on in neutral the instant MPG reading shows numbers like 234mpg at 65mph. So, gliding uphill my average trip FE starts to climb again. But don't be fooled. My average between accelerating uphill and gliding uphill goes down still, just not as fast or as far. The gains on the shorter flat and slightly descending sections are high enough to fully compensate--even though the flat sections are shorter than the uphills.
“P&G is currently defined as accelerating at higher engine loads, followed by coasting with the engine turned off. Restart and repeat.”
I did not know only engine off was considered P&G here. Thanks.
“The only difference is he is leaving the engine running instead of shutting it off during the glide.”
Yup.
“You could use PNG-on and PNG-off to differentiate.”
Sounds good to me. GLEN was just my mnemonic device, and it carries one piece of info P&G lacks. I wanted a name that carried a reference to DWL in it. Doing a P&G, as you know, without high load, will not accomplish much other than wear-out your foot.
Fat Charlie 07-30-2011 12:30 PM
California98Civic, I don't think you're giving P&G enough credit. I don't think you can get a legitimate "A" run anymore when the mod you're deleting is your driving style.
My first hypermiling tank was 20% better than my last non-hypermiling tank, and I didn't start hypermiling until 1/4 way into that tank. The last bad tank read 22.8 on the car's display, a good tank for me back then. The tank with P&G added read 27.5 and I wasn't even good at it yet.
euromodder 07-30-2011 02:21 PM
So I thought as well.
But you quickly get used to it
That's where low rolling resistance tyres, pumped up to high pressure, and aerodynamic modifications come into play.
They'll greatly increase the glide portion.
That's exactly what quite a few folks on ecomodder are actually doing ;)
Restarting the engine is often done by briefly letting out the clutch again in high gear (5th), then shift into the appropriate gear for the speed.
(Saves wear on the ignition keyhole.)
Fat Charlie 07-30-2011 02:57 PM
Yep. The more performance you want out of your car, the more effort you've got to put into driving it.
toc- What's wrong with having to change gears? What's so disturbing about EOC at higher speeds? I feel safer then because the car is easier to steer and bump starts don't need the brief mental pause to pick the right gear.
toc 07-30-2011 06:17 PM
You'll lose brake booster function (which is from the vacuum of the engine).
The increased wear on the clutch and engine from many restart cycles (and at every 15 seconds or so, that's a lot of cycling on / off of the engine). I remember reading somewhere also the electrics can be sensitive to the rapid voltage changes that can occur by bump starting (because the voltage can bounce around a bit when starting whilst moving).
That might damage the ECU for example?
Daox 07-30-2011 06:40 PM
Plenty of us here have been using P&G for years on our vehicles. Most cars get a good 3 pumps on the brake before you run out of vacuum. Enlarging the vacuum reservoir is also quite easy to do with some PVC pipe. Most people don't bother though since 3 pumps is normally plenty. The wear on the clutch is quite minimal if you learn the proper technique. The electronics stuff isn't an issue. I've never heard of anyone having any problems with it. If it is an issue, delete the alternator! :)
Fat Charlie 07-30-2011 09:16 PM
The first time I lost power brakes when I needed them, I learned everything I needed to know about the problem. Power brakes or no, you want a healthy buffer in front of you so that you don't have to use the brakes period. That alone makes it safer, and once you've learned how much power assist your car stores then the problem is solved.
Increased wear on the clutch is only a factor if you should really be driving an automatic. The only clutch I've ever needed to replace was the one that got drenched with oil when the rear main seal went. The voltage problem with starting while moving makes so little sense that it doesn't even count as wrong. The engine doesn't know or care where the force that starts its crankshaft spinning comes from, and a good bump start is more gentle on the engine than using the starter motor: watch the tach the next time you start it with the key and note how high it jumps before it drops down to idle. A bump start is more of a nudge- it gets things moving and the engine climbs up to idle speed.
Most of my glides are with the engine on, but on the long ones I shut it off. Long downhills, stretches with tollbooths or almost certain stops at the end and the like. I'm not constantly bump starting, but I am constantly in and out of gears.
deathtrain 07-30-2011 10:01 PM
I dont mind if i lose brake vacuum. I just sold my 65 olds delta 98. it had all wheel drums breaks. was a good car and it floated at 60mph
PaleMelanesian 08-01-2011 09:17 AM
I did a cross-country trip last month, from LA to Savannah GA. Pulse and Glide the whole way. There were two of us driving. We checked one segment and we were doing about 2 cycles per mile, so the 2,500 mile trip took about 5,000 P&G cycles. Yeah, that's a lot. We also got 63 mpg crossing the country in a brand new Fiesta. :D P&G works.
Arragonis 08-01-2011 10:00 AM
I only tried EO(ff)C a couple of times in the Fabia but I used the the key to restart. I was probably over worrying about the clutch but it cost me £1200 to replace the other year. I stuck to EO(n)C instead mainly as I wanted to retain the PAS (with the engine off the Fabia was a pig to steer) and also because I was worried about heat-soak in the turbo causing the seals to fail.
Now I don't have a turbo so I may try that more, also the steering on the Aygo is dead easy with the engine off - I don't start it for rolling the car round the drive unless I need to move it up the hill.
larrybuck 08-01-2011 08:20 PM
To California98Civic and others!
It sounds like you have really GREAT GAME going on, but I was curious because I believe you mentioned that these substantial uphills are all on a freeway.
Wouldn't it be prudent on a long uphill stretch to tuck in behind a heavily loaded truck, and just putter up the hill at a relaxed constant speed?
Are the police that mean about STEEP HILLS? With the vintage of your car, wouldn't "It's a little tired, I'm trying to make it last in this economy" work IF you were stopped?
I never drive any faster than I absolutely have to!!!
Fat Charlie 08-01-2011 09:37 PM
Well, California98Civic clinically proved that while P&G isn't the best way to go up long hills, it still beats cruise. On his car, by 14%.
d0sitmatr- how much gas is left when your empty light goes on?
PaleMelanesian 08-02-2011 09:10 AM
I haven't done an ABAB test, but I have proven to myself many times over that P&G is best even climbing hills. (manual trans) I run at 80% load at all times. If that means I'm accelerating up the hill, then I do a (short) glide and then get back on the gas at 80%. That's more efficient than steady speed at 60% load. If the climb requires 80% load to maintain speed, that's still at maximum efficiency and I just call it one giant pulse.
toc 08-02-2011 09:22 AM
How is load determined?
I take it 80% load is not 80% Throttle ?
California98Civic 08-02-2011 10:34 AM
Hiya larrybuck. Thanks for the comment, hey. I agree about drafting. But this was a test of this one technique, so I had to control for it as best as I could. Drafting is reliant on the luck of getting the right situation. But yesterday I drafted a truck across a 22 mile all-freeway route (smaller hilly % than the test route) and pulled 73.2mpg at an ave 53.5mph. Last week on that route without drafting: 63.3 @ 59.4 ave mph. BTW, I don't follow very closely. Three or four car lengths is my favorite because it discourages people getting in between and seems to be as good or better than hyper close, according to Hucho's aerodynamics book.
On the puttering up a hill at a slow constant speed question. First, yes, the police will pull you over at 40 or 45 mph, and technically could any time you fall below 55. Freeways here are six lanes across in each direction and people drive 65-85 routinely. You can get killed. The slow speed would also be a mistake, probably, from an efficiency standpoint, even while drafting. Your car will operate relatively inefficiently at low load% and burn more fuel over the same terrain. I know it sounds wrong. But if you follow your gauge to appropriate high load for your motor, you can drive a little faster (saffer and more legal) and get a lot higher FE and you don't have to EOC on the freeway. But if I were to do what you describe, I would vary my speed, seeking an average that keeps me steadily behind the truck, while allowing P&G with load ("GLEN") so I can get higher load% averages out of the engine for greater FE.
As for the vintage of my car... I hear you, but "this is the ship that made the Kessle run in 5 parsecs... she's fast enough..." I've been dodging the empire for decades.
:D
euromodder 08-02-2011 11:14 AM
That's right.
It's 80% of the work the engine can do - as seen on an OBD tool like the ScanGauge or Ultragauge.
With my diesel I can be at 95+ % load with the accelerator pressed down less than 1/4th.
Pushing it down further doesn't help once beyond 98%.
It just tries to add more fuel.
PaleMelanesian 08-03-2011 09:58 AM
80% load comes from a Scangauge or Ultragauge. It's in the 33-50% throttle range at these low rpms.
Piwoslaw 08-13-2012 03:30 AM
On my way out to vacation I got a chance to do ~90km on the highway in relatively flat terrain (we usually go to the mountains, so most of my long distance driving is rolling and hilly terrain). It was not a pool table, but pretty close, it was much flatter than anything I've driven on in the last few years. I decided to use this chance to check the efficiency difference between steady, cruise control driving and PNG (P&G in Neutral, ie with engine on).
Since this came up at the spur of the moment, the test is not exactly ideal. The only thing I could come up with was to watch the engine coolant's temperature as a measure of efficiency. The outside temperature was ~21°C (68°F) with a strong side wind. I had my radiator's lower grille blocked (upper grille and intercooler were unblocked). Each try lasted at least 5-6 km (3-4 mi) to allow everything to stablize.
  • Driving on CC at a steady 95 km/h (59 mph) leveled the coolant temp at 92°C (198°F),
  • Driving on CC at a steady 90 km/h (56 mph) gave 91°C (196°F),
  • Pulsing to 100-105 km/h, then engine-on coasting to 80-90 km/h quickly brought the temp down to 86°C (187°F), and after a while to 84°C (183°F)
During vacation I planned ahead so that on the way back I could do a better test. This time I made sure the distances were the same on each try and I used the car's OBC to measure fuel consumption and average speed. I tried to make sure that average speed during PNG was the same as the set CC speed in the previous run. Unfortunately, I wasn't able to do as many tests as I had planned - during the fourth run our infant son started crying and I had to make an emergency stop for an hour:(
Outdoor temperature was 32°C (90°F) with a headwind, lower grille block open. Tests #1-3 were 12 km (7.5 mi), test #4 was 8 km (5 mi).
  1. Cruise control at 94 km/h (59 mph), engine load 40-60%, consumption 3.5 l/100km (67 mpg), coolant temp 81°C (178°F),
  2. Pulsing to 105 km/h (66 mph), engine-on coasting to 85 km/h (53 mph), average speed 94 km/h (59 mph), engine load ~80% while pulsing and ~25% while idling, consumption 3.1 l/100km (76 mpg), coolant temp 79°C (174°F),
  3. CC at 90 km/h (56 mph), consumption 3.4 l/100km (69 mpg), coolant temp 82°C (180°F),
  4. PNG between 80-100 km/h (50-63 mph), average speed 90 km/h (56 mph), consumption 3.4 l/100km (69 mpg), coolant temp 81°C (178°F).
NOTE As I found out during the tests, #3 was slightly downhill towards a large river and #4 was climbing back out of that river basin. This explains why PNG had the same average fuel consumption as CC at the same avg speed.
Summing up, of all of those tests only #1 and #2 on the return trip are anywhere close to ideal tests. They imply that driving at a steady 94 km/h consumes 13% more fuel than PNG between 80-100 km/h with the same average speed. Again, this was in flat terrain during hot weather.
This means that PNG is still efficient on flat roads at highway speeds up to 100 km/h. Since the speed limit on this highway was 140 km/h I could have tried to find the break even point, but that wouldn't have been fun, since I don't like going that fast. My guess is that CC starts to take over when the engine is at constant 80% load, assuming that gearing allows rpms to stay in the ideal range for best BSFC. In rolling and hilly terrain I'm sure that PNG would allow better performance, since it would be possible for the driver to syncronise pulses and glides with hills.
As a side note, please praise me for going at only 2/3 of the PSL;)
MPGranger 08-13-2012 09:34 AM
:D
Umm... Han? Isn't a parsec a unit of distance, not time?
Fat Charlie 08-13-2012 10:53 AM
Route planning is a big part of hypermiling.
There was a cluster of black holes near Kessel. The normal smuggling route steered well clear of it and was 18 parsecs long. If you've got the speed, you can fly closer to the black holes- and the Falcon was fast enough to make that route in under 12.
I find your lack of faith disturbing.
Piwoslaw 08-13-2012 11:06 AM
In the cosmos time and distance can be interchanged by multiplying/dividing by the speed of light.
A parsec is about 3.26 light years, so 5 parsecs would be 16.3 (light)years? A 16 year old car isn't 'vintage' yet, is it?
California98Civic 08-14-2012 07:11 AM
Yes, but that was not in the script: "You've never heard of the Millennium Falcon?…It's the ship that made the Kessel Run in less than twelve parsecs."
:eek:
HaHAHAHA!
