P07 wiring questions
1st post here, a little about my setup...
I've got A 90 Crx dx, it had a b18b1 in it and sucked at FE (26-29mpg) So I sold the b18 and bought a d15z1 (jdm d15b)30k mi) an 88 HF tranny(58k mi), new clutch kit, new axles, new wheel bearings, plug wires, starter, alt, belts and a 195* thermostat. Ive got the old out and the new In, I'm at the stage where I still have to solder a few plugs And harnesses in. I'm trying to wire up my p07 to a d15z1 in a 90 Crx, I need to know the pinout for a lean-burn "on" light, vtec "on" light and upshift light. Any ideas? It's the p07-a00 model ecu And what sort of relay could/should I use to power the led's? I've used a ton of 87a relays so I understand how they work. The link in the mods list is down... |
