01-27-2012, 02:06 PM
The Saudi Terminator
40 mpg s10 2.2L
My question is how possible would it be to get a 2.2L s10 5 spd with a 2.41 gear rearend to a achieve 40 mpg?
1993 Geo Metro- 361k on original drivetrain minus head. Best mpg of 75.23. Grille block,mirror delete, kammback, fender skirts, and 135-80-15 tires..... Oh and alot of Hypermiling techniques.
01-27-2012, 02:13 PM
Not without aeromods and/or a lot of low speed P&G.
01-27-2012, 08:56 PM
oldschool
Well at first I thought that's not enough gear to be able to use your 5th gear, but then realized that a 2.2L was the Isuzu diesel (1985).
With whatever factory gear they came with (was often 3.73:1 or 4.10:1), the old EPA rating for highway was 36 mpg, and the new rating is 33 mpg, so that's really not that far to go.
I would say that it's very possible.
The 1985 model was not heavy.
Diesels handle the extra loading from the gear superbly, and you just might realize a very efficient combination with it running at such a low RPM at speed.
Compare Side-by-Side
Edit: maybe you meant the 2.2 Vortec SFI ?
Sorry If I got confused.
01-27-2012, 08:57 PM
oldschool
...ooops
I was trying to edit above post and cat hit keyboard. lol.
01-27-2012, 09:45 PM
Is it a 2.2L diesel?
01-28-2012, 10:52 AM
No gasoline...
01-28-2012, 01:36 PM
oldschool
You would likely have to boost your low RPM torque by quite a bit to be able to achieve your goal. It would be difficult, but not impossible.
01-28-2012, 01:42 PM
Sounds like fun to me .....
01-28-2012, 06:29 PM
#9 (permalink)
This.
And make sure that the engine is not going into fuel enrichment when driving at low RPM.
01-28-2012, 07:03 PM
#10 (permalink)
At what rpm does this happen?
