Parallel Programmer
I have made my programmer using this method ( Arduino - ParallelProgrammer ) but I am not sure where to hook it up on my spiffie kit MPGuino. I see 4 sets of 2 jumpers (8 total) near the buttons... where else could it go?
thanks, Shane |
You probably need an isp connector for that programmer (2x6). The spiffie should be programmable with a standard usb cable though, like hooked to most printers/scanners these days.
yeah, I had the resetting issue and it won't boot up now. I've tried to upload a new sketch, can't find it. Need to re-boot it.
2 Attachment(s)
You can rig up connections to the appropriate isp pins on the cpu with whatever you have handy. Here is a schematic that has the isp mapping:
http://www.arduino.cc/en/uploads/Mai...-schematic.pdf I made an "in circuit" adapter for my ftdi cable out of an extra DIP socket (plus hotglue and careful bending of the tips, reset cap, etc, etc). I just press it on while programming. Maybe rig something like this up if you plan on doing it more than once. http://ecomodder.com/forum/attachmen...1&d=1236055998 http://ecomodder.com/forum/attachmen...1&d=1236055983 |
Sorry for the stupid question, but what pins are what on the ATML chip. I know what numbers to tap into, but the chip itself isn't numbered.
Thanks, Shane |
I have everything hooked and i open the code in arduino 0011 Alpha (is this the right program?) It gives me an error;
avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51 I have tried to run it with USB powering it and without. |
yah, the parallel guy is flakey in my experience. I wound up loading a bootloader and verifying that it worked by watching for the blinking.
