Old 02-13-2008, 11:32 AM   #1 (permalink)
Another Autospeed aero article: methods for measuring aero drag
http://autospeed.com/cms/A_109741/article.html
They describe a different method for measuring aero drag. Not bad, but I wonder how accurate it is. Its hard to say if a MAF sensor's voltage is directly proportional to engine load. For example, say you get 1 volt @ 60 mph and you are using 10 hp to maintain that speed. Does .5 volts mean you are now using 5 hp to maintain speed? I wouldn't be too sure. But, it is a way to measure improvements.
Old 02-13-2008, 12:23 PM   #2 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I just can see that working unless you are on a dyno. Finding a perfectly flat road with no wind. That's a tough order to fill.
"Judge a person by their questions rather than their answers."
Old 02-13-2008, 12:32 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I saw this yesterday also. I really like the DIY + empirical mindset at that publication.
Ideally, someone could calibrate direct sensor measurements against a SG or SuperMID, and post the information for others who don't have the $ to spend on the OBD2 computers, or whose cars are pre-obd2.
Old 02-13-2008, 12:57 PM   #4 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
For us - it would be better to consider a relative measurement (power is going to depend on a few other factors in addition to MAF readings and will vary from car to car). I think it would be pretty safe to say that given mostly consistent conditions - if ABA testing shows .5V - 1V - .5V... there's a benefit
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 02-14-2008, 12:34 AM   #5 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
some of the error from wind and terrain can be canceled by driving both directions on the same road the same day.
another trick i mounted a TPS(throttle position sensor) on the linkage to my diesel injection a couple years ago, i read the ohms at a steady 55 both directions on the same day, change something, go run again, gives me a relative power level for the price of a TPS. would work for suspension travel also.
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 20 03-18-2014 05:31 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
