EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   The physics of walking (https://ecomodder.com/forum/showthread.php/physics-walking-11871.html)
TomO 01-15-2010 11:12 AM
So when I was in 8th grade my science teacher was discussing physics with the class. He stated that the reason you move forward when you walk is because the Earth is pushing back on your foot as you push on the Earth. He also stated that when you drink from a straw, the air pressure outside of the straw is pushing on the liquid forcing it up the straw when you decrease the pressure within the straw.
I told this to a class of 5th graders at my work yesterday and they didn't believe me, lol.
It all makes sense though...For every action there is an equal and opposite reaction; you push on the Earth with your mass and the Earth pushes back with an equal force but since the Earth's mass is greater than your mass, you move.
I remember Asking my Science teacher a question after he said all this to us: "So what happens when I jump? Does the Earth move towards me?". He answered "Yes, but the movement is so minuscule that it cannot be measured".
So was he razzing us back then or what do you believe?
luvit 01-15-2010 11:44 AM
am i walking east or west? am i waking to the engine or the caboose?
every action has a reaction, but really.. my suckiness is what makes my soda move in my straw..
i move because i try.. and i fight gravity.
in school i was told all kinds of things that were wrong:
blood in the body is blue until it is exposed to oxygen in the air, then turns red.
i was also told that buffalo were extinct.
tasdrouille 01-15-2010 12:20 PM
Some things just work, and most people are satisfied not knowing how they work, but we ain't like most people are we?
If they don't believe you, why don't you show them? I particularly like this example of Newton's third law : "When you punch an object, the object applies equal force back on your fist. You may experience this reactive force as pain."
shovel 01-15-2010 12:21 PM
werd, we get told all sorts of silly BS as children, like that gravity is a "pull" force and that some invisible sky wizard fashioned us out of dust to be his playtime pals.
NeilBlanchard 01-15-2010 12:34 PM
No, I push the Earth, therefore I move more than it does.
MadisonMPG 01-15-2010 12:57 PM
If you sucked on a straw, and the atmospheric pressure outside the straw decreased exactly as fast as you could suck, you would get no drink.
It takes two to tango.
gone-ot 01-15-2010 03:57 PM
...some long-dead famous British guy once said: "...every action has an equal and opposite RE-action."
TomO 01-15-2010 04:17 PM
Hmm, I could punch one of the bigger fifth graders to demonstrate this, although I might lose my job, lol.
I like not being like other people, but being like the people on this forum. So wait, that makes me like you people even though I like being different from other people...And that makes me unique! Just like everyone else! :thumbup:
Frank Lee 01-15-2010 05:26 PM
Smokey says think of engine induction as atmospheric pressure pushing air/fuel into the engine, not engine vaccuum pulling mix in.
gone-ot 01-15-2010 05:58 PM
...true, but in the "Three Little Piggies" nursey rhyme, they don't "...SUCK the straw, wood and brick houses down!"
KITT222 01-15-2010 06:16 PM
I think this might be a variant of of whats up there, but I think people push off of the earth. If the earth were to push back, than what would happen if I had a friend walk away from me in the same line? Its just confusing the way its phrased.
Bicycle Bob 01-15-2010 07:19 PM
Try imagining that you are on a space walk, and have a heavy weight on one hand. If you push it away, your combined center of gravity stays in the same place, so you move away from it also. If you are dealing with a satellite that weighs the same as you, both objects would move the same amount. If you grab the space station, you do most of the moving, but it still shifts.
So when you raised your hand in class, the earth moved away from your hand a tiny amount, and also slowed it's rotation due to increased moment of inertia. The theory is easier than the physical measurement of the extreme example, though.
J.E. Gordon has some choice paragraphs on how floors push up on your feet in "Structures." Also a cartoon, captioned "Do stop pulling on kitty's tail, darling!" "I'm not pulling, mummy, kitty's pulling!"
thatguitarguy 01-15-2010 08:32 PM
I don't know how many other people notice it, but I find it much easier to walk in an Easterly direction because it is counter to the Earth's rotation.
I'm thinking that there are enough people on this planet that if we all got organized we could all walk to the West at the same time and slow the planet down to make the days longer.
theycallmeebryan 01-15-2010 08:33 PM
Bob explained it about as easily as it comes....
so kiddies, if you ever find yourself floating away from a spaceship in space and you happen to have a tool with great mass in your hand, throw that tool in the direction opposite the spaceship and it will either slow your movement down (if you have more mass) or will allow you glide back back to the ship (if the tool has more mass).
NiHaoMike 01-15-2010 09:58 PM
The force will act on both objects. With two objects of the same mass, they would accelerate at the same rate but in opposite directions. Let's suppose Allie and Shannon each have a mass of 50kg, and they're ice skating, so let's neglect friction. If they start from a standstill and they push each other away such that Allie has a final velocity of 1 m/s North, Shannon would have a final velocity of 1m/s South.
If the same situation happened but with Mike (75kg) instead of Shannon, Mike would have a final velocity of 0.667m/s South. With Jean (150kg), she would have a final velocity of 0.333m/s South. If there was a 1500kg car (in neutral, neglecting friction and angular momentum) instead of the other skater, the car would have a final velocity of 0.033m/s South.
Finally, let's have Allie push against a wall that is firmly attached to the earth (6x10^24kg). The change in the earth's surface velocity would be 8.3x10^-24m/s. That is insignificant enough to be impossible to measure. Therefore, it is neglected.
It feels like PHYS 218 all over again...
bgd73 01-16-2010 11:36 AM
your science teacher drives a front wheel transverse drivetrain. It brings a disease to teachers as well.
weirdo.
he forgetting we got two legs attached to the hip, attached to a central nervous system...attached to...
a bit more than a foot is happening to walk, we kill most of the energy away with a pendulum of balance, before even moving forward, unless sprinting like a steroided olympic runner...or an inline four....
you know 200% more effort for 20mph faster rather than torquing balance.
:rolleyes:
the same two feet could be pumping a gear ratio on crank...for 40mph faster...
linear to revolution, it is sOOOOOOO confusing for people who end up in charge of it's engineering. :eek:
not to be evil. We all got a path. me typing with two fingers for example..highly unlikely pc builder, and runner...
those that do get a real balance through thier heads end up the leaders for a long time, nameless.
how is that good for marketing eough food for 1 billion people?
god comes down like a haitian eartquakle eventually. stand leaders stand.
pstrbrc 01-16-2010 03:54 PM
One would think that where you live, walking south would be easier, north harder. (Isn't it downhill from Leadville to Buena Vista on US 24?) :D
Piwoslaw 01-18-2010 08:32 AM
I levitate.
