Pizza pan wheel covers - smooth or perforated?
I'm going to buy a set of pizza baking pans as wheelcovers and I have a dillema.
On one hand there are smooth pans which are a perfect aero choice - proven and nice looking. On the other hand there are perforated pans - easy to mount with zip ties and probably allowing better brake ventillation. Any help choosing? |
Smooth is smoother. :)
Brake cooling has to be taken into account though. Most ecodrivers don't use their brakes hard/long enough for it to be an issue though. If you live in mountainous terrain, that may be unavoidable. |
Your brakes should get adequate ventilation from the inside edge of the wheel, I'd think. Ask around, it may be I'm totally wrong.
Next time you do brakes get ceramic pads along with drilled rotors. Heat will not be as big an issue then. |
single perf
Jabb,a sweet compromise,is a single opening which allows access to the valve stem and also vents braking air.An image of such a setup is from the Renault Vesta-II,146-mpg concept.The image is in "Other vehicles 1, page -1,line-1,second photo, @------------------------------------------------------- Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - aerohead's Album: Other vehicles 1 - Picture
Things are not always what they seem. ;)
Really, if you are a semi-decent ecodriver, and unless like Metro said, you're going down a mountain, you are not going to overheat your brakes. |
