Placebo Effect
I was wondering whether sometimes mods have a placebo effect. For example, I recently switched to some lower weight synthetic oil, which has resulted in some record-breaking mileage for me. I'm wondering though whether it's really all the oil or not. Could it be that the oil does provide some benefit, but much of the benefit comes from me looking at my mileage display and thinking, "Wow, this is a really good day today, maybe if I really focus, I can break another personal record." So, for example, maybe the oil provides a 5% improvement, and my increased focus provides another 5% (maybe?).
I'm not sure if there's really any way to prove or disprove this. Anyone else thought about potential "placebo effects"? |
All the time. Practically need a double blind test to avoid it.
It might not be related, and/or the difference may be within testing noise.
You often read on performance sites that placing magnets next to the fuel lines increased both power and fuel economy, for example. |
Diesel_Dave -
I only make hard claims on three things, driving style, one-size-up tires and my taller 5th gear. Recently I've also had some really good tanks after switching from 91 to 87 octane and slightly modifying my side skirts. But in the background there is also the possibility of warmer weather and a change in the gas blend. One thing I think happens a lot is that someone joins this group and makes a mod at the same time they are improving their driving style for MPG. They make the mod, are more attentive during the mod, and improve their MPG as a virtue of changing the way they drive. Now, which helped more, the driving style or the mod? CarloSW2 |
more fillups, the better for the average
Yeah, I think there is certainly a placebo component.
You mentioned positive thinking over a potentially record-breaking tank. Sometimes the reverse happens too, when you get behind an erratic vehicle, or hit a few extra lights on your commute. It's like you know it's going to be lousy no matter how hard you try. Although it's not magical, I think it has everything to do with focusing - or not focusing - on success. |
The placebo effect should be listed as a real mpg saving technique, it causes the driver to drive at his utmost best.
Vortex generators could improve everyone's mpg. Magnets and acetone can make you drive smarter ! |
And a good tank reinforces the driving habits caused by the placebo effect, thus "proving" that the change resulted in better mileage.
How about a new mileage technique: Using Placebo (TM) to improve driving skills. |
What we are talking about is not 'truely placebo effect' (as frank stated)
here is an example: I give frank lee, Darin and Carlos each a geo metro to drive. I tell Frank Lee and carlos their cars are exactly modded to achieve optimal mileage. (for the sake of the test I have only increased the air pressure in Carlos tires to 48psi, frank lee & darin are at 32) Frank is the placebo. Darin knows that he has no alterations and just drives. Frank Lee thinks he has a 'modded' car and subconsiously drives better. Carlos gets better mileage because of the mode (and subconsoiusly drives better) In the medical/pharma field, the placebo effect can be as high as 15% of the blind group can 'feel' a positive result of the sugar tablet. What we experience is really a 'shadow' effect. or ghost effect. or guilt effect. But I agree that it exists. |
Aw Man, I wanted the modded car!
believe me....I gave A LOT of thought as to who got which car :D :thumbup: |
Wikipedia is our friend: List of cognitive biases - Wikipedia, the free encyclopedia.
See Experimenter's Bias and Selective Perception. |
I learned back in college about placebo, test bias, and test procedure. I did a bunch of aeromods and coast-down testing and wanted so badly for the data to confirm the efficacy of the mods, but it didn't. And that's what I presented in my paper even though cherry picking "favorable" results did cross my mind.
Ah, but didn't you use a shaky measurement technique that relied on you watching an analog gauge & manually pressing a stopwatch start/stop? There's a lot of wetware in the methodology adding to the experimental noise.
--- Related to this topic: http://ecomodder.com/forum/showthrea...ery-11445.html |
There sure was!
If you want to experience a true demonstration of this effect, buy an ecomodder sticker and put in on the left side of your car so you see it every time you get in your car.
To this day, I swear it has some magical MPG boosting effect. |
You can find several sites that promote mpg. But you feel like you have to get a 'pocket protector' to post there on a regular basis. Or give up your believe in physics and chemestry. Here there is the idea that anyone can play in the sandbox:thumbup: That has a very 'it's ok' sffect on each persons efforts to get better mpg!:D |
In my case, I have to take the long look at what I am doing. I have no scangauge, no instant gratification, and I drive the truck sporadically. It takes me months to really accumulate enough data so I gave up on ABA testing. I just do things that are proven to help, sit back and enjoy the 'ride'. I'll make three changes to the truck in the course of the next tankful.
skyking -
CarloSW2 |
As you suggested If the driver was too lose interest his gains would disappear. |
That's the reason I'm trying to stray away from my normal lurking and actually get involved with the forum. I've read other posts in the past that confirm this. |
