EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   PLX Devices releasing smaller $89 OBD-II MPG gauge (https://ecomodder.com/forum/showthread.php/plx-devices-releasing-smaller-89-obd-ii-mpg-6750.html)
MetroMPG 01-13-2009 10:26 AM
ScanGauge Junior?
PLX Kiwi MPG - MPG Meter, Trip Computer, Engine Check Scan Tool, OBD2 OBDII Gauge
Sunnyvale, California January 2, 2009 – PLX Devices Inc. today introduced the Kiwi MPG. The Kiwi MPG is a small, low cost, device which displays your vehicle’s fuel efficiency information. This includes instantaneous MPG, trip MPG, and dollars of gas consumed in an easy to navigate 4 digit display.
The Kiwi MPG installs into any 1996 and up vehicle, in a matter of seconds. Kiwi MPG is a plug and play device which interfaces with your existing OBDII port, often located near or under your steering column. Its dimensions measure just 1 x 2.5 x 0.5 inches, which makes it ideal to be mounted virtually anywhere. Kiwi MPG will begin shipping in March 2009 for a suggested retail price of $89.99 (US).
http://www.youtube.com/watch?v=dqIN9nImrpk
I suppose this will prompt Linear Logic to follow suit. I would be surprised if they don't already have a "ScanGauge Jr" type of product designed and waiting in the wings.
Intrigued 01-13-2009 10:29 AM
Cool!!! Finally something I can use at a price that I can afford... :D
Daox 01-13-2009 10:41 AM
Interesting. It would be interesting to give this one a try. It is a good deal cheaper than the scangauge. However, it doesn't appear to be able to display more than one sensor reading at once like the scangauge does.
PaleMelanesian 01-13-2009 11:57 AM
The big Kiwi would reset every time the ignition was cycled off. That includes shutting down at lights while stopped. I wonder if this one is the same. That's a deal-breaker to me.
Intrigued 01-13-2009 12:16 PM
Did you watch the YouTube blurb? It says there that at key off the MPG goes into a low power mode, and resumes at next start... which might mean an improvement...
I suppose (guess) it has a separate power tap, which could be wired to a constant hot. I wish they would get them out before March, so that someone could get one and tell the rest of us!
PaleMelanesian 01-13-2009 12:25 PM
Ah, I missed that. Youtube no worky at work. :(
That's at least an improvement. It certainly LOOKS great, better than the SG.
cfg83 01-13-2009 12:36 PM
PaleMelanesian -
The YouTube ad claims that it goes into standby mode and restarts where you left off.
I want to know what it's "settings" are. Do you input the engine and tank size ala SG? What are the "big Kiwi" setting inputs?
I do like it's form factor. Very convenient for installation.
CarloSW2
93Cobra#2771 01-13-2009 02:56 PM
Me likey. Nice price alternative to sg.
Magister 01-22-2009 01:35 PM
This device only display number.
My OBDuino project can display all OBD information as well as MIL code, and fuel consumption for trip, tank, etc.
It's still in development and can cost half of this gizmo :)
rmay635703 01-22-2009 07:14 PM
So where do I buy one, oops it seems that it will ship in march, I guess I have to wait a bit :(
The Atomic Ass 01-27-2009 01:57 PM
Install a manual cutoff switch perhaps? I don't like the idea of cycling the ignition myself, as I'm a stereo ***** and hate my tunes being interrupted. :D
The Atomic Ass 01-27-2009 01:59 PM
The ODB connector has a constantly hot wire. The Kiwi probably turns off when the computer stops responding.
smartzuuk 03-11-2009 12:49 AM
The large Kiwi was a sack of non-sense, and didn't work properly in three different vehicles I tried it in. Until I see a blazing review, I'm suspect.
xboxmookie 03-25-2009 08:20 PM
almost the end of march... anyone get their hands on one yet?
rmay635703 04-18-2009 01:54 PM
I am wondering on that too, I have heard some bad things but can't verify anyone actually has this paticular model?
SVOboy 04-18-2009 01:56 PM
I've been wondering the same things...
smartzuuk 04-19-2009 02:47 AM
delays, delays..... waiting on the blazing review...... if it is just borrowing code from the bigger fruit, then well........ it'll not be that great of a deal. But I'm open to learning that they've worked out the bugs with the programming.
also note, the screen on my larger kiwi went south.... got some 'ink blotch' look to it now on one side
rmay635703 04-19-2009 06:32 PM
That is my problem with practical devices looking "pretty" Reliability should always trumpy eye candy, especially on a heads up display that is just for showing raw data.
Hopefully their "Kiss" version followed the kiss principle and is more practical and reliable, I might have to break down and buy one and see how long, but blast over $100 with the shipping to me, another $50 and I have a scamguage.
