EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Polishing headlight lens (https://ecomodder.com/forum/showthread.php/polishing-headlight-lens-29721.html)
Joggernot 08-12-2014 02:03 PM
I haven't seen this lately so this is what I've now done.
1. Washed the lens good and rinsed well.
2. Polished the lens with Silicone Dioxide polish and old t-shirt. Anyone who cuts and polishes rocks will give you 1/2 to 1 ounce if you know them.
3. Dried the lens with another rag and let it set to make sure it was dry.
4. Mixed 50-50 Helmsman Clear Gloss with UV protection with paint thinner (didn't have mineral spirits).
5. Applied the mixture in a very thin coat using a 1" foam brush.
Picture shows the results. Almost look new!
Things to do next time...pick a day when the wind isn't blowing...:(
http://ecomodder.com/forum/attachmen...3&d=1407866535
http://ecomodder.com/forum/attachmen...4&d=1407866535
whatmaycome14 08-12-2014 04:12 PM
Looks good! I have been needing to do this, thanks for the reminder.
