EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Possible rear bumper mod (https://ecomodder.com/forum/showthread.php/possible-rear-bumper-mod-15837.html)
Staska 01-19-2011 09:31 AM
1 Attachment(s)
Possible rear bumper mod.
If one could remove trunk for spare wheel and bottom part of rear bumper and connect it with bottom cowering plate - it should be efficient and less costly than roof chopping. It would be ideal for sedans with long rear.
Frank Lee 01-19-2011 10:19 AM
Can't have much rise before flow separates there, rendering the effort useless.
Staska 01-19-2011 10:41 AM
1 Attachment(s)
Of course you are right. 14-15 " wheel is about 20 in diameter with tyre. So we could have bottom partial kamback 20" length. It is more in length than more of top kamback..
Frank Lee 01-19-2011 10:51 AM
That red curve is too steep and I'm quite sure wouldn't represent an aero improvement over stock.
Staska 01-19-2011 11:22 AM
Ok. That kind of slope in degree we would use ? 10-15 or less ?
brucey 01-19-2011 11:58 AM
4 degrees is what the number is around here for the bottom.
I think it's 10-15 on top.
Piwoslaw 01-19-2011 02:33 PM
That depends on the chassis shape: A fastback or sedan has lowest aerodrag (Cx) around 3°-4°, but a squareback (like the Fiat Idea you used as an example) is better off with a flat rear(*).
(*) If the car already has a Kammback, then it is no longer a typical squareback and a slight diffuser angle may be OK.
On the other hand, race and performance cars have more aerodrag Cx and less Cz (= more downforce) when the diffuser angle is greater than 5°.
Either way, getting rid of, or covering up, a spare that hangs down in the air flow is something to think seriously about.
Tango Charlie 01-19-2011 09:03 PM
That's usually where the muffler is hanging out, too.
