EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Post up your OBD-I fuel consumption via the MPGuino or similar! (https://ecomodder.com/forum/showthread.php/post-up-your-obd-i-fuel-consumption-via-5292.html)
roflwaffle 09-28-2008 05:45 AM
As well as engine displacment/idle rpm if possible. Just cuz I'm curious! I've read that many older vehicles, even going back as little as five years, see significantly worse fuel consumption compared to displacement and I was wondering if anyone else had an real world experience regarding this. :thumbup:
ac7ss 09-28-2008 03:38 PM
I have a '92 Mazda b2600i 2.6L Manual. The (Now calibrated) MPGuino states that I get 27.8 mpg averaged over a 50 mile freeway commute. Idle RPM is in the 600 rpm range.
ptsmith24 09-28-2008 03:47 PM
I'll try and remember to post my results once I get my 'guino dialed in. In the meantime, you could look at the fuel logs. I'm sure it would take some time to sort it all out, but that's one source...if I understand what you're looking for correctly.
roflwaffle 09-28-2008 11:00 PM
Doh, I forgot to mention that I'm looking for idle fuel consumption. :o
ac7ss 09-29-2008 04:09 PM
MPGuino does not have a GPH display on it yet that I know about. It could easily be put in the custom screen from what I have seen. How about it?
dcb 09-29-2008 05:38 PM
Actually it was in the last update.
Originally Posted by dcb (Post 62295)
9/20/2008
updates for v0.73
replaced RPM with GPH on custom screen, more universal.
But I think meatsicle is looking for the data from the EOC/idle screen (left twice from the custom screen)
ac7ss 10-02-2008 04:06 PM
Ok, since I had to re-program the settings anyway (Weird lockup) I updated. It is telling me .55 GPH in idle, warmed up, lights off, neutral.
92 mazda B2600i 2.6l
roflwaffle 10-02-2008 09:55 PM
Thanks for the info!
