EcoModder.com
-   For Sale (https://ecomodder.com/forum/sale.html)
-   -   Potentiometer Speed Controller / Throttle for EVs (https://ecomodder.com/forum/showthread.php/potentiometer-speed-controller-throttle-evs-12046.html)
fourthgen 01-26-2010 06:01 PM
We manufacture a Potentiometer Speed Controller similar to the Curtis PB-6 PotBox.
http://www.fourthgen.net/images/Potbox1.jpg
PB6 PotBox for Electric Vehicles
Product Features:
1. 0-5K ohms potentiometer
2. Hard chrome plating
3. Robust construction and rust proof
4. Built-in Micro Switch
5. Fully compatible replacement part for Curtis PB-6 PotBox
6. Shipped worldwide
7. Used in electric vehicles, golf carts, electric fork lifts, pallet trucks.
8. Great for electric vehicle conversions.
9. Performance guaranteed
10. Only costs $64.99. FREE SHIPPING.
Visit us at fourthgen.net
for more information
RobertSmalls 01-26-2010 06:41 PM
I just bought a two-axis pot from DigiKey for $5.74. What's so special about yours?
dcb 01-26-2010 07:47 PM
the price is better than most for a whole pot box, but I'm going homemade too (hall effect rig on one and a repurposed throttle position sensor on another).
gone-ot 01-26-2010 09:31 PM
...go electronic and use the hall-effect output to drive power FETs (acting as resistor).
dcb 01-26-2010 10:11 PM
works for low power, but in high power they should be either on or off with minimal time spent inbetween, cuz a lot of heat will be made otherwise.
NeilBlanchard 01-27-2010 07:58 AM
I'm just finding out more about these -- I've heard that the Hall effect units are temperature sensitive?
dcb 01-27-2010 08:24 AM
perhaps the hall effect is, but it can be compensated for with some slop in the software throttle map, or with a thermistor/other circuitry if that isn't an option for you.
Also it *should* be more reliable since it doesn't rely on physical electrical contact like the wiper on a potentiometer does. But mine is off a $20 used scooter so I'm not real concerned about that :)
I was referring to the FET as having to be either on or off, in high power apps, just for clarification.
I did just realize that if you are converting a car, that you should think about just keeping the throttle body with the gas pedal and cable and throttle position sensor intact and just use that. The TPS I got from coyote (mid 90s metro?) is about 6k and should work nicely in many applications, and have all the travel and cable bracket issues sorted out already.
