Pre OBD Mpg Gauge??? Not Vaccum Gauge
Does anyone know of a MPG Gauge that you can buy that shows true real time miles per gallon?
Of course there's Scangauge for newer cars, but I drive a Car from the 80's and probably will continue for a long time. I bought one that came out in the 60's but it only goes up to 25 miles per gallon, and doesn't come with instructions :confused: (it's a really complicated analog computer) Someone's gotta make one that's better! |
If you're fuel injected you can use the mpguino.
Welcome to EM |
I can't type all those extra words, :p
I seek one too. 87 carbed sube. Must be dynamical. I can go from mini dragster 20s mpg into the high 50s. all same engine, same carb same everything. Real engines do this, ECUs don't :confused: <-as you can see its a blue serious face versus -> :)
I had heard or maybe even seen the old mpg computers in a gm cadillac or maybe pintiac, thay had strange gadgets... anyway, the limit was the problem indeed. they used alot of fuel back then... |
Hey got an extra carb laying around? |
A lot of BMW models came with a MPG gauge. I had on in my 325ES, but it may be a PITA to get it to talk to the rest of the car...
