Even if it's speed RPM limited, wouldn't lowering the load be beneficial?
The way it has been explained to me is that no matter if you reduced the load to zero, you would have limited benefits in mpg.
You would max out at around an 8 - 10 mpg improvement.
Instead of getting Aerocivic like numbers at 65 mph, you would max out at 58 mpg.
( With an unmodified baseline of 48 mpg @ 65 mph )
It IS an improvement, but not worth the effort.
I recently took a trip from Houston to Austin, and drove behind a UHaul truck for 90 % of the trip.
This guy was going painfully slow, but I decided to drive behind him and see what numbers I got.
His speed ranged from 48 mph to 52 mph the entire way there ( 75 mph posted speed limit, with some areas going to 85 mph - the highest in the USA ! )
I drove at around a two second gap and could not see his mirrors.
I managed to get just over 66 mpg.
But this was a combination of the extremely slow speed as well as the drafting.
What this tells me is that this car is just not going to give any good MPG numbers if I aeromod it.
I saw the post earlier in this Darin getting over 70 mpg at 50 ish mph .
That's encouraging, but I'd really like to read those results of the 65 mph tests with the aeromods.
