EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Preventative methods for windscreen misting? (https://ecomodder.com/forum/showthread.php/preventative-methods-windscreen-misting-41202.html)
Bm93 12-01-2023 06:42 AM
I want to get to a point where in the winter I don't have to faff about waiting for the windscreen to demist in the car in the morning.
I was thinking about bulk buying Silica Gel Packets and leaving them on the dashboard, or getting a dehumidifier, but I was wondering if anyone had any successful methods that fixed the issue for them?
oil pan 4 12-01-2023 08:48 AM
I put a small electric heater in my car and power it up 30 minutes to 1 hour before I leave.
Bm93 12-01-2023 09:50 AM
I've bought some big dehumidifier bags to see if they're effective, but that seems like a decent idea. Is yours battery powered or does it need to be plugged into the car?
freebeard 12-01-2023 01:13 PM
https://www.amazon.com › Rain-X-630046-Interior-Glass-Anti-Fog › dp › B00T9LR9FA
Rain-X 630046 Interior Glass Anti-Fog - 12 fl. oz. - amazon.com
$5.95 & FREE Shipping Sold by: Parker's Home Store Rain-X 630046 Interior Glass Anti-Fog - 12 fl. oz. Visit the Rain-X Store 4.0 4,979 ratings | 43 answered questions 7K+ bought in past month $597
redpoint5 12-01-2023 02:26 PM
Silica gel cat litter (usually blue colored) is the same stuff used in those little packets as a desiccant. I bought a bag to solve that problem in the Prius, but it turned out my fogging issue was the result of the windscreen not being attached and water getting in. I attached the windscreen and solved another water leak and that solved my issue. Never did get around to filling tube socks with cat litter and seeing if it would help, but it's a cheap thing to try.
Other than that, I'd be tempted to install a block heater so the car warms up quickly and has hot air to clear the windshield.
As an aside, silica gel can be reused by heating it in the oven.
jakobnev 12-02-2023 08:27 AM
I've been using silica gel for years, I also started using warm water bags:
https://ecomodder.com/forum/showthre...joy-39046.html
Piwoslaw 12-09-2023 04:16 PM
Been using a sock filled with silica gel cat litter ever since jakobnev recommended it so many years ago.
I heat it for 3-5 min in the microwave @50% power, wait for it to steam off its moisture and cool down, then throw it back into the car.
I don't remember the exact numbers now, but i weighed the sock before and after heating, and it appears to capture 30-50 grams of water.
to_achu 04-16-2024 07:01 PM
I put on my heater and open up the window a bit, when the fogging is gone I turn it of,let the window sit open for most of the heat to leave, Than I close it.
