prius cvt maximum power
anyone know the limits of the prius transmission?
Prius doesn't have a CVT
I was hoping someone with more knowledge would respond, but nobody has made a peep. I found a nice old description of the original Toyota synergy drive and the Honda IMA here by The Eindhoven Technical University. Figure 4 shows that the Prius Internal Combustion Engine (circa 2004) could produce about 100 nm. Figure 6 shows the electrical machine characteristics. MG1 can produce up to about 80 nm. (oddly, the motor & generator curves for MG1 are symmetrical) Formula 2.6, shows the relationship between the ring gear rpm and ICE rpm and rpm of MG1. Essentially MG1 sets the equivalent gear ratio. For example if MG1 is held at 0 rpm then the ring gear will spin at 1.46 times the ICE speed. If MG1 is made to run at twice the ICE speed then the ring gear will spin at 0.57 times the ICE. And if MG1 runs backwards at twice the ICE speed the equivalent ratio is about 2.37 (btw I used the ratio given in the Eindhoven paper 78:36. But everybody else says 78:30) This variable ratio scheme works as long at MG1 can produce (or absorb if running as a generator) enough torque to "over power" the ICE torque. The ratio between the engine driving the sun gear and MG1 driving the planet carrier is 30:23. So MG1 only needs to produce about 76% as much torque as the ICE at any rpm. Getting back to your question, if you wanted to attach a synergy drive to a more powerful engine, you'd need to replace MG1 too. There are very similar eCVTs on other cars too, the Highlander Hybrid has a 3.5 L V-6 that produces 336 nm The Lexus GS 450h says 360 nm. So they must have appropriately powered MG1. -mort |
From the way I understand it, Generation 3 Hybrid synergy drive is universal for Prius, Highlander, and Lexus versions. The different applications generation of electricity may not be effected by the size of the engine in this particular application as the engine, regardless of size, is attached to a eCVT and completely computer controlled system which both generates power with and puts power into the MG1 assembly of the transaxle. But if you use a Prius transaxle in a custom application with new motor controllers...
so what if i put 3-400hp/tq through it
I don't think it designed to handle that much raw HP. Look at the HP rating of the three hybrids I mentioned and you might be able to get away with another 20-50hp but then again it could blow up.
Like mort said above, I'd say the issue is the capability of MG1. Mechanically, it's just a planetary gearset, which I would assume can hold a LOT of power without busting. There's no clutches or anything like that. You could probably replace MG1 with something else (like a strong DC motor) or rewind it for more amps, but then what would you control the whole mishmash with? THAT would be the complicated part. BUT...if you succeed, it would be the coolest thing ever!
Persanity's understanding is a bit off. Each of the different classes of hybrids that Toyota makes has a different transmission, each transmission is designed to mate with a narrow range of gasoline engines and drive a certain size car. The heart of the Synergy drive is MG1, the transmission ratio selector. It must produce enough torque to counter the ICE torque through the planetary gears. The big rear wheel drive Lexus cars have a 2 speed planetary gear changer in the transmission for a wider operating range. The LS 600H has a 350+ HP V8 and a 120 HP traction motor compared to the Prius 98 HP engine and 22 HP motor. You know the transmission in the Prius and the 600H are not interchangeable. -mort |
so im better off trying to find a ls600 setup
If you're planning to put it in a rear-driver, yes.
I do recall Autospeed turbocharging a Prius, but they never got anywhere close to those torque figures... maybe nearer 200 ft-lbs. |
I don't want to argue but I don't believe they do have different versions of the hybrid synergy drive eCVT.
There is a gen 1 a gen 2 and a gen 3 system. All versions of each generation are the same across each hybrid application. I believe one exception to this may be the synergy drive in the hybrid civic. It makes no difference as far as FWD or AWD/4WD to the original application because all these synergy drive eCVTs are for FWD applications. A synergy drive in a vehicle with AWD/4WD has a seperate differential motor. If you want rear wheel drive you could modify one of those motors. Used hybrid eCVTS and used hybrid components in general are a great source for large powerful electric vehicle equipment. Where else can you get a 50KW motor for $200-500 dollars? |
Here's a neat site: ToyoDIY
You can search by car and then cross reference by part number, for a start 2010 Prius uses a 30900-47060 or 30900-47061 transmission the 060 crosses to the plug-in Prius the 061 crosses to the Lexus CT200H (which lists for $3,160.10) 30900-48070 or 30900-48090 Highlanders cross to Lexus RX350H ($4,125.94) 30900‑33011 Hybrid Camry ($4,290.54) 30900‑75040 Lexus HS250H ($3,409.61) 30910‑30020 Lexus GS450H (Lexus list:$16,774.68 dealer price:$5,421.47) 30930‑50050 Lexus LS600H (Lexus list:$38,579.97 dealer price:$7,242.76) -mort |
