Prius Question
I'm posting this for a friend of mine that owns a prius and he has a question about pulse and glide with the prius.
His question was is there any benefit to neutral coasting (vs. just coasting in drive) with a prius since he assumes fuel is not being used when the car is coasting in drive after pulsing the pedal and releasing the pedal. Because the prius switches to battery power when releasing the gas pedal is there any benefit to pulse and glide with the prius? I'm really not up to speed on how the prius works but I told him my fellow ecomodder's would defiantly have an answer...thanks! |
I found neutral gliding helpful when the engine was cold.
neutral gliding in a prius or your civic? Just to clarify...specific to the prius because it used gas and battery powered engines...is neutral coasting beneficial vs. in-drive coasting?
I am by far not an expert in Prius Drivetrain, but I would think that it may not matter with a prius because the Prius should disengage the tranny when coasting, since it was designed for that. The only thing that would slow down a prius during a coast is the regenerative braking, IMO. By switching into neutral you may by pass that system, which would be beneficial, but you would also eliminate the regen braking which may not be so good.
This of course is all theoretical ... |
In a prius. I found that the engine tries to warm up and runs quite a bit more then it needs to so I would put it in neutral to glide so there weren't any arrows on the screen. Pulse and glide is deff worth it in a Prius but the point is to accel and glide without any arrows, not worth it imo to try and use all electric assist all the time.
There are quite a few good guides online on proper pulse and glide techniques specifically for Prius's. Driving the Prius normally = 55mpg, pulse and glide = 75 average |
My guess was that pulse and glide in a prius is not "AS" beneficial as in a normal engine only vehicle since the engine is essentially shutting off after depressing the brake pedal and switching to battery power anyway.
I use P&G in my 4runner and obviously the benefits greatly impact my mpg but I'll have to do some more reading on the prius to see what benefits, if any, there are for doing it in the prius. Please keep the responses coming as I'm trying to help a friend with this thread! Thanks! |
The benefits would be amplified with the prius.... Even though you are using the electric motor most of the time in the city, by P&G, you use less power from the battery, therefore extending the range, thereby using the gas engine even less ...
So if there are area to explore Prius P&G, visit them, squeeze every drop out of that puppy. Nothing pisses me off more than watching a Prius blow my doors off @ 80mph on the hwy .... |
Good point Trik!
My friend is at about 52mpg right now but uses no P&G...he does drive cautiously and rarely revs the engine (and never abuses the gas pedal). I know he'll never do an aero mod but he does plan to inflate tires to near-max psi soon. I'm guessing with high psi and more attention paid to P&G, slow gas pedal, etc. he would be around 60mpg. |
For more info on P&G, see my comments at the link below: Toyota.com : Hybrid Synergy View : 2005 : Fall : Prius Marathoners Top 100 mpg |
Thanks for the great info Kraus! Interesting reading even though I don't own a prius...will be a great help for my friend. Would love to see him pull 65+ mpg with no major aero mods other than psi and P&G.
