Prius Race Car? - Yep.
I think it may lose a few mpg's in the transformation...
Toyota Prius GT300 Race Car is Mean and Green: 2012 Tokyo Auto Salon | AutoGuide.com News http://www.autoguide.com/gallery/d/4...2/_MG_1705.JPG |
that's kinda cool.
Great, now the streets will be filled with Prii with fart cans in no time!
...wonder how they handle the "re-fueling/re-charging" issue on a road-race (ha,ha)?
A friend had his leaf out autocrossing. It didn't do that bad, and didn't deplete the battery as suspected. I have changed some peoples opinion about diesel performance. However, its much older technology and you could see my carbon footprint up in smoke. :-\
Changing public perception isn't always bad. Most people in US think diesel is slow like a semi, reliable as an old GM diesel V8. Electric car = golf cart death trap that will only go 20 yards at 5mph. Know what I mean? |
Like the cliched wisdom that racing and wars improve the breed, the technological advances are created, tested and verified on the fields of war/competition. Many rolling laboratories that achieve success are implemented on our everyday vehicles. (Carbon fiber, superchargers, disc brakes, tire compositions, active suspensions, DOHC, ABS, ESC, DSG, ...even the rear view mirror) Toyota Hybrid Le Mans Race Car Revealed | AutoGuide.com News
..I wonder how much they learned from this winner and improved the next Prii gen. http://www.autoblog.com/2007/07/16/h...okachi-24-hrs/ |
So, the prius is gonna run LeMans?
Excellent. I would be willing to bet the Audi TDI stomps it's arse, at the pump and the finish line. :) |
Drool!!!
Regardless, I believe the TDI would stomp any gasser hybrid. The reason for this is I don't believe regen braking at the retina detaching levels required for such racing is efficient. I could be wrong though. If such power storage is possible through really fancy capacitors, such a drivetrain might compete with the oil burner. |
braking in a racecar is to short and to hard for a proper regen, thats true. and immaterial for us.;)
[QUOTE=pete c;280912Regardless, I believe the TDI would stomp any gasser hybrid. The reason for this is I don't believe regen braking at the retina detaching levels required for such racing is efficient.
I could be wrong though. If such power storage is possible through really fancy capacitors, such a drivetrain might compete with the oil burner.[/QUOTE] That's why Porsche uses flywheel storage in its hybrid race car. More efficient than batteries (and maybe capacitors), and can accept energy at any rate up to the point where wires start melting. |
The suspension helps with maintaining speed through corners, less braking = better gas mileage. But good gas mileage takes an incredible amount of self-control with a turbo. Just a slight hill and the stupid engine starts boosting and you are putting 100 horse to the wheels, just maintaining your speed. So, I normally don't bother. |
Audi has some very good diesels, but diesels suffer more at high rpm than gasoline engines, and the thermal efficiency of racing engines is quite high. Turbocompounded F1 machines I believe can be 40% efficient. It's not safe at all to assume a diesel has an automatic, significant advantage due to typically higher efficiency, especially in racing where lugging that extra engine weight around hurts a lot. |
^^^ We'll see if diesel-hybrids have any disadvantages compared to gas-hybrids in competition. Biggest endurance competition.
Audi confirms R18 hybrid as part of 2012 endurance racing program |
Wow, that's great news. Competing systems will develop the technology much faster.
