Problem changing EPA combined in Garage
Hi,
Currently using the 22mpg US combined figure for my Saab on my fuel logs. I feel this figure is a bit harsh and giving a larger % increase in my efficiency. I've amended the combined value to 24mpg US but It soesnt update the graph or details on the fuel log screen? How can I force it to take 24mpg as the base? Or will I ahve to re-log the whole thing? Thanks Neil:confused: |
(alt F5 or just F5 on windows ? ) |
tried CTRL F5 for forced refresh- Data on the Graph Has not changed!
think I may need a Mod/Admin to advise on this.. cheers for the suggestion though! |
Give it a few hours then look again. That is how long it takes for my fuel graph to change.
I'm seeing the 24 in your vehicle details, so we know your change is in the database.
However I don't think changing the EPA value generates a new chart. To do that you'd have to submit a fuel log change. Try simply editing & resubmitting (without changing data) one of your previous entries. I bet that works. (Don't forget to refresh your cache as previously mentioned.) |
