Problem with coolant flow?
Looking at the Lancer today I've found an issue with coolant flow, I thought the thermostat wasn't opening so I've replaced it today and refilled with coolant, I ran it in and couldn't get any decent temp on the return hose.
The feed was noticeably hot, but the return cold. The fans were running fast. This has been an ongoing issue and I reckon has been affecting FE - the fans appear to spend a great deal of time running to me. I made the coolant mixture stronger (50/50) instead of 33%, and similar results. Today going for a drive I decided to stop pulse and gliding and instead keep the rpms to speed and this appeared to be bringing the temperatures down (noticed on the gauge the temp was down). The theory is, when I pulse and glide, during the pulse the coolant flows fairly well, but the glide causes the timing belt driven water pump to spin too slowly to get the flow required and so the fans run a lot more often then they probably need to. Q 1: What's going to be more efficient to use - fan electrical energy or pulse and glide? Q 2: What solution exists to this problem? I don't want the head overheating to the point it warps, but likewise there's little point in having the fans running if the thermostat hasn't opened (feeling the return hose it's not very hot, but low flow would also do that). I'm looking closely at the sensor too - I had the car off and checked the temperature sensor with a multi meter and it's reading 0.08 to 0.10 kOhm, so the manual says 0.26 - 0.36 would be around 80 deg C - I left it some time - around 15 minutes or more, and it's dropped to 0.13 to 0.15 kOhm - not a great drop in temp, would it be ? |
If you can put a ScanGauge (or maybe an UltraGauge??) in it you should be able to read engine temp digitally.
My Civic also doesn't cool the coolant much when at idle speed. I think that's pretty standard with an engine-driven pump. Sorry I can't try interpret the temp sensor data. Radiator's return hose should feel cooler than the upper hose, definitely. The fans definitely put a load on the alternator and thus on the engine. I avoid any setup that causes my (single) fan to run a lot. That definitely affects your fuel economy. |
Have the radiator checked for partial blockages. I would think a 2004 model would still be good but radiators will transfer less heat when they get older, just like cholestrol in humans restricts blood flow. Also make sure the cooling system is "bled" properly if you have done anything that could cause an air pocket, which can also cause the problem you describe.
regards Mech |
good call OM, years ago I had the same air lock on a fiero, got rid of the air and no more overheating the head. now for my 2cents if all is found ok how about drilling a bigger bypass hole in your spare thermstat and test that, it will flow more cool anti freeze at a lower speed on the pump
The sensor right now is reading 0.98kOhm, which according to the factory manual is about 40oC - it's been off all night, so I don't think that's right (or the manual is wrong). I'll swap out the sensor, and get a higher flowing thermostat and see if that fixes the issue. EDIT: The manual was wrong (it refers to two sensors in the same year - the sensor appears correct based on the right values). As for air in the system, I can't see any bleeder screw to release air, and I did run the system in with the cap off through to operating temp and then some, and then filled until it dropped no more. I don't think there is air in the system but I'd like to find a way to be sure :) |
With the cap off, squeeze the upper rad hose repeatedly.
It's got to be a flow issue, the stat opens and the pump is spinning off the timing belt. Electric Water Pumps (EWP) These have the right idea, shame about the pump price though - a bit high. |
toc I just reread your post and you say the supply is hot and the return is cool could you have the flow reversed , some cars run the cool water to the head first and some to the block first whats the manual say. I think some cars run both fans when the ac is on .
My driving today just proved it.
There's nothing wrong with the sensor, the fans appear to be working as intended (i'd love a current switch to determine for sure!). The design isn't great: The sensor before the thermostat drives the coolant temp gauge, the fans have a fan controller that operates on PWM. The thermostat opens at 82oC. The fans appear to run around 82 and up (just guessing). The fans try and control the one coolant sensor. There's not enough flow through the radiator when I pulse and glide, There's two possible ways I can fathom that would be better: - A temperature sensor at the top of the radiator - the fans modulate to maintain that temperature at like 75.' - An electric pump, get rid of the thermostat, and the pump runs as needed at speeds as needed resolving the flow issue. Since the thermostat is out of the equation and the flow maintained correctly, correct temperature conditions are maintained. The first would control the fans better then using the one in the block - but to put it together I need to find the known values that the fans turn on / off at (I hope it's higher than 82!). Better flow will result in an even temperature so an electric water pump would be nice, but this presents a problem - The timing belt would still be driving the old pump, I'd need to remove it to get the best results which means removing the load that pump puts on that belt and maintaining the pulley in place - the only way I can think of that would do this is cutting the fins off the pump giving it no coolant to move. This is all up in the air though, I don't realistically know how much fuel it takes to pulse and glide and run it hot (but i'd still be concerned about the head with low flow). |
still not making much since . does it overheat at idle, the system should cool no matter what. unless 1. blown head gasket, 2. oiling problem 3. air lock
It runs the fans a lot.
The fans run a lot at idle due to the low flow from the coolant pump due to low RPMs. I don't sit and idle in traffic a lot, but what I do is pulse and glide. When I pulse and glide the car fans appear (unconfirmed at this time) to be running. The fans run becomes the temperature sensor is hot. It's hot because there's not a great amount of flow coming from the pump at lower RPMs. To increase flow would mean to increase RPMs, and therefore affect fuel economy. The test I did today was pulse and glide and simply watch the gauge, the gauge rose. I then held the RPMs up with 0 throttle rolling down hill and as expected the temperature dropped below it's standard operating temperature. Essentially the problem is the pump doesn't flow enough coolant through the thermostat if the RPMs are low, the fans run but as they are controlling to a sensor in the coolant before the thermostat, they are trying to cool with no coolant due to low flow. I'd love to be able to monitor coolant flow, and show the problem but the above driving shows the issue. The fix is of course to increase flow so that pulse and glide doesn't get a lot of heat, and the fans are off more (thereby fixing the fuel economy). Since I only filled up recently, I'll be testing fuel economy with no pulse and glide this tank, to see if the increase in fuel due to no pulse and glide is measurable (giving two results in theory - how much does pulse and glide really save me). |
Maybe it has a plastic water pump impeller that has disintegrated- happened to Moon Unit. I'd never heard of that happening before and gee was that fun to diagnose and fix. :/ The replacement pump has a cast iron impeller LIKE IT SHOULD.
Nah the impeller wasn't plastic - I replaced that pump when I replaced the timing belt, just weeks after I got it.
then check it it may have been manufactured with the wrong rotation. for standard belt and is reversed with serpentine belt
i'm not sure i really understand what all is going on.
i was hoping you could try to list out all of your symptoms, what you can see or hear, and when it does what. without listing possibilities, or likely causes. "hot" might not be sufficient information, 190 or 230 i would consider hot, but the difference is huge in looking at cooling issues. and you might have to get some sore of scanner to see data. any dash lights on? or dtcs? i think a car being P&G'd could potentially set a p0128, and command on the cooling fans. could there be a coolant level sensor at play? revving the engine might get coolant to the sensor and when at idle it commands the fans on. |
Well I ran the entire tank with no pulse and glide, and so the temperature sensor was down.
The fans are on when it's not hot, but I can't tell if it's speed related (i.e. if I am idle and barely moving the fans come on). I realise I need numbers to discover the temperature that is being seen, but I've only just got a circuit together that can talk the proprietary Mitsubishi Protocol (OBDII isn't supported). It appears I can get the temperature of the coolant from that. I figure we should change the control of the fans and replace the Mitsubishi fan controller with my own (using an arduino). I know the thermostat opening temperature is 82 deg C. I know it's fully open around 12 deg C above that. I know the fans must run when the thermostat is open. The fans I don't believe (am I wrong?) should not be running, if the thermostat is closed* - but they appear to be (see this is why I need the coolant temp and fan running status - to prove they run needlessly). * - Except when the A/C signal is on for condensor reasons, but I don't normally use A/C. |
ever think its time to (i hate to say it) go to a good mechanic for a check only on the scope, or just change all the related components yourself at the same cost. Before the engine gives up from overheat related problems
Have you replaced the fan controller yet? I would be very interested in an arduino fan controller. I am in the process of replacing the belt driven fan on my Mercedes C220 with an electric fan and possibly an electric water pump. I was thinking of using an Arduino to control it but I have no experience with that platform.
Yeh - the fan controller works good.
The existing fan controller received an input from the ECU about how fast / slow to modulate both fans. I picked that input up and put two relays in (one on each fan). It wasn't overheating at all, the controller was definitely running when no fan was being called for. Fuel didn't seem to get affected too much, so it must not have been running all the time, but still - fixing it was better. As to your issue - some things to think of. - Removing the belt - does it have other pulleys on that belt? Finding a belt suitable is a consideration. - The fan running all the time means that you only have the thermostat's opening temperature as your possible setpoint for operating. You'll need to find some wiring for the ECU - you'll want the pin that has the coolant temp and buffer it off so you can get that as an input. Calculating temperature - you'll need to find the temp sensor's scaling to find it's temperature. Air con pressure switch - since the fan is belt driven, there probably isn't an input for the AC high pressure to run the fan for condenser. You'll need an input for AC high pressure to run the fans. Fault scenario - your sensor is open circuit - run the fans. |
