problems with lean burn in my civic vx
i just bought a 92 civic vx a week ago, working out the kinks.
it feels like when it should be going into lean burn, warmed up, at cruising speed, light throttle, it stumbles or misses as if it was running out of gas. if i give it just a little more throttle say from 20% up to 25% runs fine again. also if i am driving down a hill in gear, where i think it should cut fuel to the injectors the check engine light comes on until the car is turned off again. any vx owners had either of these problems? or know how to check the check engine light code? thanks much for any ideas |
My lean-burn issues seemed to be traced back to faulty (re-)wiring by the previous owner, although the code said O2, along with a few others. You can use a wire to jumper across the 2 prongs in the green terminal hanging under dash by the pass. door to see what the codes are.
Check your connections under the hood along the right pass. fender. Maybe plug & unplug each one a few times to clean up terminals. Then check the wires leading to the ECU by the pass. door pillar (under the dash) for any ghetto re-wiring. |
thanks i will check out the wiring before i start spending money.
I got a great deal on my civic vx for the same issues and I bought it because I was 99% sure that it was the o2 sensor, replaced the o2 sensor and it runs perfectly.
The o2 sensor does not always trips the check engine light when it is first wearing out but it sounds like yours is pretty far gone. It will be a bit pricy but if you search around you can find them for $100 or so, otherwise auto part stores sell them for $300. |
And congrats on finding a VX, bryn. Envious.
Did you figure out what the problem was? I'm having the same issue. Unfortunately for me it's not the 02...
I've cleaned the EGR ports and valve, seafoamed the engine...:confused: |
