Project: Slippery When Wet - 8th Gen AeroCivic
haha i couldn't think of a better thread title so meh :D
I know i have another thread here doing some stuff to the car but that was before i lived in a house where i could actually do things to the car! So here's the plan... Full upper and lower grille block because it gets down to -50C here in the winter. I moved here a few months ago and installed a block heater so that's covered. Tonight I'll be heading out to do some ABA testing of the lower grille + fog lights with painters tape before i start making something permanent. who wants to place some bets on what i will gain doing about 100km/h? im guessing 2MPG :cool: BTW i tested the upper grille a long time ago with some clear poly film and it gave me 1MPG (not very scientific) at hwy speeds...second pic **EDIT** well since this thread isnt very exciting and has no replies i thought i would just add onto this post. this was on about an 8km stretch where i went out and back...had to throw out some results due to traffic. Bottom grille and fog lamps were covered with cardboard. No pics it was dark. A - No Grille - 5.0L/100km - Out A - No Grille - 5.3L/100km - Back B - W/ Grille - 4.9L/100km - Out B - W/ Grille - 5.0L/100km - Back A - No Grille - 5.1L/100km - Out A - No Grille - 5.1L/100km - Back A - No Grille - 5.2L/100km - Out Looks like about a 0.1-0.2 L/100km (approx 1-2MPG) change or 2-4%? What do you guys think? not enough data to be considered accurate or does it look promising? http://i60.photobucket.com/albums/h1...s/IMG_0591.jpg http://i60.photobucket.com/albums/h1...s/IMG_8503.jpg |
2-4% sounds about right for a grille block.
I assume you have a ScanGauge to monitor coolant temperature? Won't be much of an issue in February, but you don't want that radiator fan running more than it needs to before then (or worse). |
Yup i have a ScanGauge
On my first run with the lower grille blocked plus tape on the top the temp climbed to 210F when the normal is 190F so i took off the top tape. ...And after seeing the fairly reasonable gains i started to construct my Semi-Permanent "remove on the fly" lower grille block + fog light covers. http://i60.photobucket.com/albums/h1...s/IMG_9698.jpg |
