Project Slow-Moving Metro
http://i157.photobucket.com/albums/t...psfe8d216e.jpg
Hi guys! Bet it's not the Metro you expected! :p I've been on and off the site for a while, but I finally decided that I need something that will permanently get me good fuel economy for the long run! I was looking at just buying a new-ish hybrid, but decided that it would be more fun to try to build my own. The car is a friend's Nash Metropolitan that's been sitting for a few years, and is A) Pre-smog (California)...B) Light (1800lb curb weight) and C) A free test bed, so aerodynamics be darned, we're going to try it! Right now I have an older Briggs and Stratton Etek Motor and Alltrax controller that should be good for about 20hp and 30lb-ft (peak) and is about 5-6hp continuous. To this we're going to add a small 15-20hp gas or diesel engine, to try and get the Metro up to 50-60mph for long distances. Or, I might do two Eteks, and use a Generator to charge the batteries. Not sure of the exact mods yet, but it will mostly be an around town type vehicle for starters, as I'm hoping it'll go 25-30mph on electric power alone. I figure that 35-40hp total ought to get it up to speed pretty quick, if we can keep the weight low enough. I had a Chevette that weighed 2500lb with driver and had 51hp, and for the most part (other than hills) it was ok. On flat ground it could get up to about 78mph, so I'm thinking that with the Nash, it will take considerably less for a 50-60mph top speed. Anyways, that's the basics, I wouldn't expect this thread to move very quick or be updated that often (hence the name...it's a pun, get it?) But hopefully I finally am able to do something with this motor after years of it sitting. Any advice is welcome! |
Diesel = cheaper to run, gas = cheaper to buy
The needed HP sounds close, as the metro lsi has 45hp and weighs 1624?lbs . |
Hooked me with the thread title... Staying for the unique project!
Is there supposed to be an image in post 1? |
Yup, I see it now on the laptop, but not on the phone earlier. Dunno what was up.
I'd like to put a 1.0 Metro drivetrain into an old Metro, fwd and all.
Ok first question...given a weight of say, 1800 pounds, a frontal area of 20 sq ft, and a drag coefficient of .50, how much hp will it take to go down the road at say, 50mph? I used RBR Racing's aero calculator and came up with 12.6hp, but not sure how accurate it is.
https://www.rbracing-rsr.com/aerohpcalc.html |
That sounds about right, roughly. I'm thinking it might be just a little low, but close enough.
It's got front and rear wheel skirts already! :p With a (close to) full grille block it shouldn't have half bad Cd. I have long wanted to try to make a vintage-looking fiberglass kammback though, and this might be a good candidate if you end up wanting a little better cruising economy.
I subbed this so hard. The old Nash Metro is one of my all time favorite cars, and one of the original economy cars. It is a thing of old school beauty.
Being so old school, there are lots of little aero mods to be made that will pull your power requirements down. Maybe not into the range of a single Etek (nice score finding an original B&S one, BTW), but any improvement is an improvement. I chance to know that the underside is about as smooth as the craters of the moon, for instance. It's also nice that you have such an obviously old tiny car. Nobody will expect it to be fast. It is its own apologist. |
Cool project... :thumbup: There's plenty of room in that engine bay for a small 4cyl Kubota diesel. Then lower it a little and you'll have a super cool fuel sipper that looks like this. http://i536.photobucket.com/albums/f...ps39d0f41d.jpg > |
I'm really liking the idea of trying two Etek's with a diesel generator now. Drive one day on electric, next day with the generator on to recharge the batteries when traffic isn't moving. Had that idea after commuting 40 miles in Los Angeles for about 2 years. Average drive was 1-2hrs one way depending on traffic. A lot of sitting. What's the most I could put to the batteries to charge them amp-wise without them overheating? I know they have 48 volt alternators for power generating windmills and such that can put out up to 190 amps! Seems like a lot, with no electricity going out. |
Ok, the plan is getting a little more solid. I'm grabbing a second Etek and going to use two for the project. That means 12hp continuous, and 40hp peak at 48 volts. Going to mount the motors right to the rearend with a gear reduction, and then create a whole "regeneration rig" with a small 15-20hp engine and 48V alternator designed for windmills. Seems a lot more complex than just doing a small 20hp engine alone, but I think this setup will give a lot better city mileage, and better overall power than just a small gas or diesel engine alone. I'm also looking at having the motors be mounted on the ends of plates that look like traction bars, so the whole setup can be transferred from vehicle to vehicle with ease. Here's a few pics of the Etek, for those who've never seen one. They're incredibly powerful for how small they are. Only about 20lb.
http://i157.photobucket.com/albums/t...e/DSCN1585.jpg http://i157.photobucket.com/albums/t...e/DSCN1586.jpg |
I'm somewhat familiar with DIY, lightweight, 48 volt electric cars. :)
Done the math to figure out what amperage you're talking to get 40 peak hp? It's way more than my controller could do. |
I have an Alltrax 400amp controller, but the Etek's only rated to 330amps, so I used that number. I've heard of people running them up to 480 amps and 96 volts (which would be about 63hp x 2 = 126hp) but I'd only expect them to last a few quarter mile passes at that load and speed. If you want to do the math, they make about 1.2 inch-pounds per amp (some list it as 1.14).
That Swift is cool. |
JQMile, I can't tell you just how enthused my wife is over your project. I'm completely serious, she saw your Metro and squee'd, then saw the motor and squee'd again.
I don't know how your project is playing at your house, but it's a winner in mine. |
Ok, we went a little past "hey, we should do this," and did some poking around the Metro and a little cleaning. Our first thought on looking at it, was "there's no way this will work, it's too low," but there was a surprising amount of room under there...kind of like the book The House of Leaves, which is about a house that's bigger on the inside than the out.
Anyways, looks like the batteries will fit nicely behind the front seat, the motor (which is still in storage, so I used a Cummins diesel crank pulley for sizing) looks like it will fit right by the rear axle with no clearance issues, and I am pretty sure a small generator will fit in the trunk. So far so good, now it's time to get the electrics up and running on a test stand :thumbup: http://i157.photobucket.com/albums/t...ps286588c0.jpg http://i157.photobucket.com/albums/t...ps8086e053.jpg http://i157.photobucket.com/albums/t...ps041280c8.jpg http://i157.photobucket.com/albums/t...psfcf4bb95.jpg http://i157.photobucket.com/albums/t...psfc456f8b.jpg http://i157.photobucket.com/albums/t...ps62212286.jpg http://i157.photobucket.com/albums/t...ps49417836.jpg |
