Propeller vs Direct drive
Off the wall question;
What is the difference in efficiency between propulsion from a propeller vs a direct traction drive (wheels, including drivetrain losses)? My research lead me to some odd vehicles, and more questions as usual. http://i.kinja-img.com/gawker-media/...c10kqfhjpg.jpg http://i.kinja-img.com/gawker-media/...ha1ou1bjpg.jpg http://i.kinja-img.com/gawker-media/...o2hnwkojpg.jpg http://i.kinja-img.com/gawker-media/...a05nnvejpg.jpg |
True, I'm thinking around 45-70% of direct depending on pitch. Not sure though.
Using ηp=T∗u/Pshaft A bad amount for mpg. The project places too much priority on weight though. http://hizone.info/data/2005/09/08/images/03.jpg http://i.kinja-img.com/gawker-media/...csnvbyljpg.jpg http://lh4.googleusercontent.com/-VJ...4/s900/p12.jpg http://www.curbsideclassic.com/wp-co...wagen-prop.jpg http://lh4.googleusercontent.com/-X4...-4/s900/p5.jpg http://lh3.googleusercontent.com/-MZ...U/s900/p20.jpg Lotus http://www.wired.com/images_blogs/au...otus_ice05.jpg http://db2.stb.s-msn.com/i/C4/C3E0EF...A9F145A7C8.jpg http://blog.modernmechanix.com/mags/..._drive_car.jpg http://www.team-bhp.com/forum/attach..._propeller.jpg http://blog.modernmechanix.com/mags/...p_tricycle.jpg http://blog.modernmechanix.com/mags/...ed_fan_car.jpg https://www.youtube.com/watch?v=xRV7RmTk2yA http://riordanco.com/jimsblog/wp-con...cycle02jpg.jpg http://riordanco.com/jimsblog/wp-con...ropcycle01.jpg http://www.sonicwind.com/image/aeroliner-1.jpg http://www.sonicwind.com/image/dragprop.JPG https://www.youtube.com/watch?v=4LJuGftUFbI http://www.petersen.org/uploads/imag...Driven-Car.jpg http://www.strangecosmos.com/images/content/144192.jpg More fun http://www.treehugger.com/bikes/the-...ith-video.html http://media.treehugger.com/assets/i.../prop-bike.jpg |
Screw the cars, now an air train, thats front page news. :thumbup: Trains doesnt have much traction, thats why they are soo efficient. They use sand to air in starting off and braking as traction is soo limited due to what little contact all that weight makes with the rails and wheels.
http://gajitz.com/wp-content/uploads...er-train-1.jpg |
I don't see it coming to a mass-production car, maybe a turbine-propelled one would make more sense nowadays.
Is there any gyroscopic effect?
As for efficiency, I expect it's much less efficient than a direct drive in stop and start driving, and I wonder what it would be like to drive behind a propellor driven vehicle in traffic! |
With enough back wind a propeller is better.
From what I remember about propellers, I think it was around 59% energy transfer before it was easier for the air to move around the propeller.
The big advantage is not relying on the wheels for traction, like has been stated, and in the old magazine clippings that is what was stated as well, ideal for low traction areas like mud, grass, ice. When I've driven an air boat, that is a boat with a flat bottom and a large prop in the back, it was very much a fluid drive, like driving a vehicle with a very loose automatic transmission. |
It would at least discourage tailgating :-)
Then you take your propeller driven car to a restaurant on a sunny warm autumn day.
You find a vacated but narrow parking slot under the trees close to the tables where people dine. It takes some manoevring back and forth to fit nicely in that slot. You'd better leave a big tip. |
Im sure small in wheel electric motors could be used to move the car in an dout of parking places, drive ways, parking garages, then once you are on the main road you fire it up. :thumbup:
Of course the real question is why? Not only are propellers much less efficient than a conventional drivetrain, they have all sorts of problems that are familiar to those of us who fly small planes, particularly off rough fields.
First, the throttle response is very non-linear. Get a wheel stuck behind a bump or similar, and you have to give lots of throttle to get over it, then you immediately start accelerating. Meanwhile, you're sand-blasting everything behind you. Oh, and that sand-blasting is also eroding the tips of your expensive prop... Nor can we forget about the interesting effects of driving in snow or freezing rain, which causes your prop to ice up & lose efficiency, and probably shed chunks of ice outwards at high speeds. (Prop tips move at a significant fraction of the speed of sound.) |
Then add the negatives of high noise levels and the effect of bird (and possibly larger animals,pedestrians, etc.) strikes on the prop and what happens when plastic bags and other road debris kicked up by traffic encounters the prop and, as a minimum, throws off the balance of the prop. Aircraft ground operations occur in the fairly controlled environment of an airport, very different (for example) from that experienced by a car following a semi in the rain or snow.
We built this for some power tool drag racing :D
It was very very noisy & very very slow https://www.youtube.com/watch?featur...-bBFLWTKkvf5Zw |
I always thought it would be neat to put a bicycle in an aero envelope and add a 50cc 4 stroke engine and one of the larger model airplane ducted fans. Pedal to get up to a speed then engage the ducted fan when conditions allowed.
regards Mech |
A ducted fan or shrouded prop would help the stop and go, allow or a low prop (CG), and make shielding easy. With pitch control the drag losses might be comparable to a unshrouded/ducted, fixed prop at speed. Both of those add weight though. Maybe some emergency floats could offset that. Did some research, oddly enough there is no law against driving with a prop, so long as your wheels don't kick up rocks. There's also the possibility of hydrostatic, but that's heavy and inefficient too. |
Off topic, but I once worked for a guy who claimed he was following California Hwy 99 north of Bakersfield in the fog, and wound up flying under a freeway overpass. |
With a regular drive-line you can get 98% with a well designed gear box or chain drive, the rest of it, tires and bearings are going to be the same because you have to have those to have wheels on the ground. |
http://http://pal-v.com/ http://www.blessthisstuff.com/imagens/stuff/pal-v.jpg Super Sky Cycle, The Flying Motorcycle | motorcycle News @ Top Speed http://i.telegraph.co.uk/multimedia/...r_2050487i.jpg Meet Dezsö Molnár and His Flying GyroCycle - Tested http://www.reaa.ru/yabbfiles/Attachm...585_331_90.jpg But I want to do it under 103. The prop idea was to reduce weigt to allow a 4 stroke. Quote:
And if you want it under FAR 103, remember you'll have to add weight for things that make it road legal, like head & tail lights, turn signals, etc. |
And having it roadable allows me to find a spot to use for takeoff and landing. At home its not a problem the driveway alone 800 feet. Destinations are a problem. A Pre-rotor would help, and may provide a method of propulsion tying into that system (if hydraulic). Quote:
My solution (with a Piper Cherokee) was to just take out the rear seat so I had room for the mountain bike. And would land on dry lakes, or the occasional stretch of deserted highway. Quote:
But I do understand about not wanting 2-stroke power. |
Bumped into this on the web:
An Aerosani (Aerosani - Wikipedia, the free encyclopedia) https://i.chzbgr.com/maxW500/2980350720/h9211431A/ which linked to The Propellor-Driven Sleigh. like this NKL-26 Russian military aerosled: http://www.aqpl43.dsl.pipex.com/MUSE...gh/nkl26_1.gif 1932 Helicron (The Helica.): http://www.aqpl43.dsl.pipex.com/MUSE...201932%20a.jpg Those last 2 and wagonloads more eye candy can be found in the Museum of Retro Technology for example the Cyclogyro (http://www.aqpl43.dsl.pipex.com/MUSE.../cyclogyro.htm): http://www.aqpl43.dsl.pipex.com/MUSE...yclogyre1a.jpg PS. saw Old Mechanic found that site first: http://ecomodder.com/forum/showthrea...gns-30553.html But it is much more than just engine designs :) |
I still like the idea of a 30-06 spitzer bullet shaped ducted fan. Very light weight and then you use the fan for higher speeds. Plenty of bikes engineered for higher speeds and relatively lightweight
If my 50 year old scooter can go 43 MPH and get easily over a hundred mpg then A bike with a modern engine would be interesting, just a small 4 stroke 50cc so it falls under scooter laws. What appeals to me is at higher speeds where you can't pedal a normal bike the ducted fan would give you thrust assist, which could be supplemented with pedalling to get to a higher speed or climb a grade' the use the fan to maintain ahigher average speed than you could ever do pedalling. Carrying an extra source of thrust also would reduce the aero drag, pulling air from high pressure areas and blasting it out in the rear in the normal low pressure area. regards mech |
If you pardon the obvious PUN, some of those propellor-driven car ideas SUCK and others BLOW (wink,wink)!
Well, that's a new twist on the situation...
It looks like the engineers thought of everything on this design. They have smartly located the fuel tank in front so that when the aircraft crashes, killing everyone, they can be cremated on spot.
http://www.aqpl43.dsl.pipex.com/MUSE...yclogyre1a.jpg |
prop efficiency
I think Hoerner gave props a maximum of around 87% mechanical efficiency for applying power to the air.
A NASCAR micro-finished driveline with 1:1 output Gear Vendors (Doug Nash Racing) transmission would be looking at around 94% overall efficiency,from flywheel to tire/road interface. |
