Pulled over, but for getting 55mpg without hypermiling.
So I wasn't hypermiling nor is my car ecomodded yet. And I still got pulled over for excessively good fuel mileage, in a sense.
I have a 1985 VW non-turbo diesel Golf. Going up Crow Hill out of Bailey I couldn't keep the speed limit. Mind you, the car is in good running condition. But by calculation, the 52hp engine is putting out less than 40hp at the attitude I was driving (7,700ft at the base of the pass.) Add that to three adults and a lot of luggage going up a long steady 7% grade. I wasn't hypermiling. I downshifted into third and glued my foot to the floor. I did keep right to let traffic by. I think I hit 40mph in a 50mph zone. My commercial driving instincts even caused me to turn on my flashers (which may have been a mistake.) Next thing I know I see someone else's flashing lights that were blue and red. I pull over and the cop says, "Is your car road worthy?" "Yes." I reply. "Are you sure?" He asks. "Yes, the car normally does the speed limit just fine." I tell him. He gives me a warning for defective vehicle and for impeding traffic and asks if I'd feel safer if he followed me home. After making it to DIA I also went to Cortez and then back to Gunnison in my "defective" VW that same weekend, over 840 miles. |
I think the flashers did it.
Other vintage cars don't do that well either on such a grade, and loaded semis would be very much slower. I made a trip around the national parks in '87 in a 2.3 liter Ford Tempo with a 3 speed auto. It couldn't hold 3rd gear on those grades, and sunk below 45 mph in second as it did not rev that well. So we had the occasional row of cars behind us. Luckily everyone was patient and once they got past many showed their compassion with a finger. I did own an '86 Diesel Rabbit, 4 speed manual. How I cursed it for not having a 5th gear. But it had a tow hook. One day I hired a trailer to move some cupboards to my inlaws in Zeeland. Driving against a storm, it could not hold 4th gear on the flat. I drove the freeways (up to 120 km/h limit at the time) at barely 80 km/h (50 mph), oil temp needle at the edge of the danger zone. In Zeeland's 2 lane no passing road a long line formed behind me. Then at ascending the Zeeland bridge even 3rd gear did not cut it any more, I had to shift to 2nd oil temp light flashing and all. I finally managed to touch the 80 km/h speed limit on the down ramp 5 kilometers further... That was an experience I promised myself to avoid from then on. |
It was a Mk2 Rabbit, but it was a while back; I sold it in 2005.
It might have been the coolant gauge after all. But I managed to light its LED. It had almost 400.000 km on the odo. It 'went to the moon' (Dutch proverb meaning gone lost or broke) and beyond, doing local commutes and shortish trips so it really had a hard life. It was done. The plastic interior parts started to break (door locks, trip reset, switches), the boot flooded with window washer liquid (all the tube joins started to leak at the same time) and it was a heavy smoker. It wasn't fast but nonetheless the speedo scale went all the way up to 200 km/h. Real top speed would be around 135 km/h, wind in the back on the flat. Fair enough, I managed to get a speeding ticket with it ;) |
Seems a jerk move to pull you over when you were trying to approach normal speeds, and a semi would certainly be much slower.
I have all the patience in the world for someone trying to do the speed limit, and none for the timid driver who is simply afraid of getting within 10 MPH of the limit. |
Crazy story!
Were there no trucks on this road also struggling to keep to the limit? Was the cop issuing warnings to them about impeding traffic? |
I even had one guy following stop where I stopped to let me know that my car was burning a lot of oil. That was back when the car was still apparently tuned for sea level operation, but since then I turned back the maximum injection so that at these altitudes I can't feel any power difference, but at the same time I've reduced the black cloud effect greatly. Since I normally drive at 7,700ft and up that's about 25% less air and therefore should be tuned to squirt 25% less fuel under full throttle. One ecomod that could be done is to figure out a way to automatically adjust the maximum injection as altitude changes. Either that or a turbo charger. Quote:
funny how by merely being slow can pull you a ticket :D here you only get ticketed if you drive a tractor on a "interstate" size road
I may as well mention that the Dasher is in the shop. I had the fuel pump replaced and the mechanic (whom I trust when he's not off his meds) delivered the car to me with a failed fan and blown head gasket. I'll have to wait for quality assurance until the owner comes back from Hawaii. (must be rough) OTOH, I've got a nominal 48hp and a 5-speed. Because of the space available with the longitudinal layout, I'd prefer a 20hp altermotor to the turbo. Or at least before the turbo. Quote:
http://ecomodder.com/forum/showthrea...tor-35003.html http://2.bp.blogspot.com/-Z4Zihl-vsj...-EASSIST-5.jpg The Buick OEM part is 1" larger in diameter, and I've got nothing but room on the underside of the slant four. The only hang-up I see is routing the serpentine belt drive around the front engine mount. It wants a ~115v battery pack. '...subscribe to you newsletter' is a trope. All I know is the valves are adjusted with lash caps. |
I'm glad you have a mechanic you can trust. I've had a bad experience with nearly every mechanic I've hired. If I didn't know how to do mechanic work, I'd be looking for a health insurance plan for my car. Good thing I like doing mechanic work. |
That's sad but I kind of understand. Many states have posted minimum speed limits (which I assume are at least de facto, if not de jure, only aimed at car drivers, or discouraging scooters and the like); others have a REQUIREMENT to use flashers under a certain speed (which conversely I've always presumed to be aimed squarely at truckers).
As a truck driver myself, I can't fault the instinct to run flashers; it's a margin of warning for those who are running high speeds behind you. I'd probably have done the same myself. Maybe as a strategic move, it's possible to use a truck as a "rabbit"? |
A flat-bed semi with a half-height load (less turbulence), going just faster than you could make on you own. They will suck you up the hill. But beware the rocks and road debris.
UPDATE!
So something I didn't mention is that I had emailed the officer about the situation, which I just noticed the reply in my junk mail folder. I very politely stated I respected his observation that the car might be "defective" but that the car was also built with very little power from the factory. On that line, I asked what else I could have done to have driven better. His response was very nice. He stated that he didn't understand why my car was going so much slower than the rest of the traffic, but thought he could use that as an excuse to make sure I wasn't drunk or something. He assured me he observed me to be a law abiding citizen and trusted my judgment. He also thanked me for being polite and interested in safe driving. He also stated that the way I was driving was perfectly legal and sent me a quotation of the law about impeding traffic that specifically mentions that a car can drive slower under such circumstances, but said he had no other recommendation of what to do other than what the law already states. So personally I feel he was being sincere both when he pulled me over and in his letter. It just felt odd to be pulled over especially for not doing anything wrong, since I hardly ever have been pulled over. And it's not like I don't ever get scoffed at for driving this car. Even close friends and family seem to think I'm nuts. |
Cops don't really pull people over for minor infractions with issuing a citation being the end goal; it's an opportunity to interrogate for something more interesting of higher consequence. I understand the necessity for the tactic, but I'll usually save them some time by stating that I'm not doing anything wrong, and that I'll be about my business if it's alright with them. It's nice the guy responded to you, but I maintain it was a jerk move to issue a warning. The conversation should have been his asking if there is something wrong with your vehicle, you stating that there isn't, and him saying have a good day and keep safe. |
