Pulse and glide experiment
Vehicle: 1993 Nissan Sentra SE, 1.6 liter, 2 door, 5 speed manual tranny
Aero mods: front airdam, about 4.5 inches above roadway Engine mods: K&N low restriction air filter, hot air intake system MPG monitoring: Sound card and MPG.java program on laptop computer. I finally got the sound card interface calibrated to my satisfaction and discovered some interesting things about how the fuel injection is programmed for this car. At around 60-70 mph, there is an increase in fuel economy at about 75% throttle, peaking at 50-51 mpg at 67 mph. Holding a steady speed at 65 gives about 42 mpg, steady speed at 55 gives about 45 mpg. This is an ideal situation for pulse and glide operation. I had a long stretch of highway to myself, with a posted speed of 65 mph. I decided to accelerate at about 75% throttle in fifth gear to 69 mph, then coast to 60 mph. I chose those limits because the Colorado State Patrol will rarely give a ticket for 4mph over the limit, and the average speed was 65 mph. With a little practice, I could coast mainly down the slightly rolling hills and through curves, and accelerate uphill and through straight sections. The mpg during acceleration varied from 41 to 52 mpg, then shot up to 250-300 mpg during coast phase. The average mpg I achieved over a 30 mile stretch was 74.54! :D After passing through a town, I had another 30 minute section of 65 mph speeds, but this time I had to use the limits of 65-69 mph, because of following traffic. I decided that if I was speeding slightly, and kept the average speed above 65, the person behind me wouldn't have too much cause to complain. Using these parameters netted an average mileage of 65.2 mpg. The overall economy of a 186 mile stretch, including 12 miles over an 11,000 foot pass, was 57.5 mpg! That's 6mpg over my best oong trip average so far, and really illustrates the benefits of the P&G technique. It also indicates to me that the fuel injection computer can probably be greatly optimized on this car for economy at highway speeds. I'm thinking about maybe some O2 sensor spoofing, to see if I can lean the mix at very low throttle openings. Anyway, I just wanted to post these results. Driving style really trumps any tweaks I have made so far... |
Very nice results.
What is this sound card interface you speak of? |
Very Cool! P&G is a lot of fun through any kind of rolling or hilly terrain. The excellent numbers make it all the more fun!
What is the 'MPG.java' program you refer to? |
1 Attachment(s)
diy mpg gauge - Page 3 - GasSavers.org - Helping You Save at the Pump
That's where I ran across the most comprehensive information. I've attached the zipped file. It's a java application that uses a soundcard input to monitor injector pulsewidth and vehicle speed. 'java -jar Mpg.zip' is the command line that you must use to get the proggy to work. I put the zipped file on the desktop (win2K) and wrote a batch file called mpg.bat that contains the line above. The program will write a file called mpg.properties that contains the scaling factors to get correct vehicle speed and mileage figures. You have to attach a resistor and clamping diode set to two places on the engine: the vehicle speed sensor, and the switched side of one of the fuel injectors. These inputs go to the right and left channel of a soundcard line input. The thread at gassavers.org has plenty of detail on how to approach this project. I found the best way was to set the speed sensor scaling first, by comparing the speedometer with the program's reported speed. I used a GPS receiver actually, as it is more accurate than my speedo in the car. Then keep the program running while you take a nice long drive- maybe half a tank of gas or more. Calculate the gas mileage in the usual way, then compare to the program, and tweak the scale factor. |
This is fantastic information. I'm a Nissan Sentra owner [and former Nissan tech] and have never seen that kind of mileage from a B13 Sentra. What else is done to the car besides your driving techniques listed here?
Mike |
The tires are inflated to 45 psi, I have a K&N air filter, I've removed the stock "Y" shaped airbox intake horn, so there's just a hole going into the airbox, and I've put a hot air intake from the exhaust manifold over to the intake box. There's also a front air dam that is just tall enough to reach below the dangly bits under the car, so that the airflow is diverted from *some* interference.
Keep in mind that this mileage is on the open highway, with a fully warmed up engine, one passenger, no AC. The latest tank is 36mpg, that's around town from home to work and such. I tried to P&G as much as possible within rush 'hour' traffic. (Rush minute, in my little home town... :D) I still want to build a 555 timer circuit that will make a 1.5 volt variable frequency/duty cycle square wave that I can add to the Oxy sensor's output, to convince the ECU that the engine is running a little richer than it really is. The engine has about 160,000 miles on it, so it's well broken in by now... |
This is great news, I saw the soundcard thing a LONG time ago but have never checked up on what came of it.
Maybe my 93 suburban could get a mileage guage with this approach, then I could determine why I have gotten up to around 23mpg when I have the thing filled to the ceiling and have a genny off the hitch and only get around 21mpg empty most of the time (my father gets better mileage half empty than me and drives it much harder, perhaps he is inadvertantly pulse and gliding as he never holds a speed on the highway) |
Jim, any new tweaks or changes you can share with us?
Have you ever considered replacing your standard 3.89 final drive gears with the 3.65 set from the '91 4-speed E model trans? Mike |
Mike, I hadn't seriously considered it. Unless the rear end gives me trouble, I'll probably defer tweaking until there's an inescapable reason to do so...
I did build the O2 sensor override circuit, but it didn't have any discernable effect. The engine computer is apparently smart enough to ignore it when I start messing around. If I recall correctly, it *did* cause the engine to stall the first couple of times I tried it, but the ECU ignored it after that. It's hard to measure any effects that aren't swamped by driving style. I get anywhere from 45-65 mpg on the highway now, just by P&G, keeping rpm's down, and coasting with the clutch out and the tranny in fifth gear. The fuel injection will shut off entirely after about three-five seconds if the car is pushing the engine. I've considered using a potentiometer to shift the DC voltage from the hot wire sensor in the airstream into the MAF. That would be an easy way to lean the mixture. However, I don't want to do that until I can also install an exhaust heat sensor that has a low enough thermal mass so that I can see hazardous increases in temperature in just a couple of seconds. The car has almost 170,000 miles on it now. It leaks oil and power steering fluid, but other than that, is running great. |
Mike |
I bet it is the front crank seal. I'll have to look in the manual to see how to fix that.
By the way, I upgraded from the soundcard MPG gauge to the Mpguino some time ago. It's quite a bit more accurate, and easier than hauling a laptop around with me. |
Very nice and interesting Jim-frank. Do you also have data on the pulse time and the glide time?
Interesting case to do some calculations if you also can give estimates for total weight and CdA of your car. What is the additional fuel to make the pulse? Meaning typical MPG without pulsing vs your 41-52 MPG during pulsing? |
I thought pulse and gliding was meant for sub 40mph speeds.
Madison-P&G works at higher speeds also.
If I watch the instantaneous mileage while I accelerate, it drops to about 30-35 (fifth gear, about 55 mph). The glide portion is getting 160-200+ mpg. The steady state mpg is a little harder to read, as the instant mpg changes sharply with very small changes in throttle position. If I look at the 'current mpg' setting on the mpguino, the average will gradually stabilize at around 42 mpg, (60 mph, flat roads, air temp about 80-90 degrees F) The duty cycle is about 10 sec accelerate, 8-10 coast. It depends, I try to use the terrain to extend the coast as much as possible. When I use P&G between 30 and 40 mph, to average 35 mph, I get about 61 mpg after the engine is warmed up. |
What would happen if you do the pulse in say 5 sec. The glide will stay at the 8-10 secs.
Will the better glide to pulse ratio compensate for the additional fuel used ? |
I've been driving in this way for about 8 years now.
I drive an unmodified 2001 Skoda Octavia 1.9TDi estate doing around 20,000 miles pa. I started driving this way after watching a nature programme on tv showing how small birds save energy when flying. They flap a few beats and then fold their wings for a while and then flap a few beats again. I thought I would try that with the car. I have been happily running at between 60-70mpg on my commutes. My best was 84mpg. I also use the display's mpg figures to dictate how I drive on motorways. If the reading falls below 50mpg I stop accelerating, if it reads above 65mpg I keep accelerating as fast as I can get away with, especially down hill in readiness for the next up hill. However, since I decided to keep to the speed limit (too many speed cameras here) it is a lot harder to get better then 67mpg. When car sharing my passengers often offer to share the cost of the fuel. If I can get better then 60mpg on the journey I don't take their money on the basis it didn't cost me any more then I would have used on my own. |
I understand it works at faster speeds, but isn't it more efficient to do slower?
What I did was to experiment a few years back.
I tried driving at a steady 70mph, then 60mph, then 50mph for my long weekend commutes. I was driving 115 miles on the motorway each way then. I found that steady speed only worked if nothing else varied. When I used the mpg computer on the dash I got huge improvements by driving to use less fuel rather then driving to remain legal. It meant that sometimes I was down to 50mph on a long up hill but then got to 90+mph for no fuel at all on the next down hill. When I timed it right it was like riding a roller coaster. All I did was blip the throttle at the crest of the hill to encourage it on a bit. It did mean keeping a good look out for the speeds and positions of other traffic and the police. When I kept the speeds legal I had to lose a lot of momentum by braking on the downhills and then using fuel to make the next climb. That lost a lot of efficiency. On the flat though, speed is a big issue and the best economy was when there were road works on the motorway with long, flat sections at 40mph with average speed cameras. If it all ran that way there would be a huge saving for everyone. I would get over 100mpg for those sections in isolation. On other 40mph roads the speeds varied too much without the cameras and other drivers would be speeding up and slowing down all the time. For fuel consumption I also found an open window was +10%, a roof rack left on was +15%, low tyre pressures was +5%, high tyre pressures was -7%, excess weight in the boot (200lbs of tools) +0% on motorway and +2% urban, climate control on or off made no difference as I think the compressor stays on regardless. Interesting one was driving around with a damaged front wing, after another driver hit me, added about 6% to the fuel used. I tried to put in a claim for that but the insurance company would play ball.:( |
janvos- I do the pulse portion in the minimum amount of time it takes to get to my target speed, which is the speed limit plus 5 mph. I then glide however long it takes to get to speed limit minus 5 mph.
Woodsmith-very interesting, thanks. Interestingly, my car shows no measurable difference in mpg with the driver's window down up to halfway. If I open it more than that, I get a very small reduction in mpg. The tire pressure makes a great difference, but I didn't see any reduction at excess overpressure. I run the tires at 45 psi; the rating on the sidewall is for 40psi. MadisonMPG- slower will always lose less energy to aero losses, so it works better at lower speeds. Up tp a point, that is... I can't go much slower than 30 mph in fifth gear, for example. The best steady state mileage in fifth seems to be at about 40 mph, which might be some kind of efficiency peak vs RPM for the engine. |
Jim,
Do you have an underhood pic of the hot air setup you built? Mike |
I don't have a picture, but the setup is extremely simple. I removed the stock intake 'horn' assembly that attaches to the intake box. It's the plastic piece that has two forks, one going forward and the other down to the intake port in the fender well. That leaves a round opening into the air box. I attached a piece of appropriate sized accordion type exhaust riser tubing that I bought at a parts store. It's about 3 inch diameter by about 3 feet long, pleated paper with wire coiled inside. I routed it forward from the air box, then across the front of the engine compartment. It's tied with wires to various points to hold it in place. The open end is then stretched out to be about two inches away from the exhaust manifold shroud, next to the O 2 sensor.
You could as easily use a dryer exhaust vent tube, the foil/wire accordion type. If I can bum my wife's camera, I'll post a photo in case my description is unclear. |
