Pulse and Glide VS DWL
Driving with load says you should hold throttle constant going up and down hills.
Pulse and glide/BSFC charts suggest you should pulse up them in low gear at high throttle and coast down. Both theories are pretty well accepted around here, but they appear contradictory to me in this area. Explain/discuss. :) |
When you get your best MPG during constant load driving, the engine isn't working at its best BSFC.
That's the key to P&G. The engine is only returning good MPG because it's hardly putting out any power. It could make more power more efficiently, if only you'd let it. But in normal driving, you can't let it as you'd always be accelerating because the engine would put out more power than what little you'd need. Enter P&G. The pulse is done near the best BSFC. MPG are fairly high, but there's also a lot of power being generated very efficiently, for a short period of time. Gliding engine-off consumes no power at all. (Keeping the engine on uses only a little bit of gas - though in a highly inefficient way) The catch is to stretch the glides to the maximum, i.e. reduce drag as much as possible. The combination of bursts of highly efficient fuel use with no fuel use at all, is often better than driving with constant load at an inefficient power setting. |
^^^ That's why MT P&G beats AT DWL, because the P&Gers only run their engines when needed, while the DWLers have to run their engines all the time when moving
So in your opinions DWL is more of a "stopgap" measure. Pulse and glide is the one true way.
Pulse and glide can get cumbersome, with traffic, repeated starts and stops on a long journey. Most use a mix of the two. Pulsing and gliding where able, dwl where unable and driving "normal" where necessary.
I am happy to be wrong about this... |
