EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Pulsing and coasting... (https://ecomodder.com/forum/showthread.php/pulsing-coasting-13510.html)
ChopsQube 06-08-2010 08:19 PM
Just a couple quick questions because I have a 6-speed manual transmission....
1) When you finish coasting, do you blip the throttle to "rev-match" or just ease out the clutch?
2) After coasting and you're back in gear with the clutch out, how much throttle do you use to get back up to speed?
I just want to be sure I'm doing this right instead of just wasting gas.
Many thanks in advance! :D:thumbup:
The Atomic Ass 06-08-2010 08:27 PM
What your fillups return will be a great (if slow) indicator of success.
RobertSmalls 06-08-2010 08:39 PM
1. It's better to blip the throttle to approximately rev match. It will save wear on the synchros.
2. There's no single answer, aside from accelerating at or near optimal engine efficiency. Wide throttle increases engine efficiency, but if you go too far, the ECU will enrich the fuel:air mixture. A ScanGauge is helpful here.
Turbo Dan-O 06-08-2010 10:51 PM
Yea, speed matching will be better on your trans and clutch and also not slow you down any. As for throttle.....I am still trying to figure this out....
Dan-o
ChopsQube 06-08-2010 11:51 PM
Dan-o
I haven't been doing the rev-matching though I kept thinking that I should since that's what I've always done when down shifting. Now I know and will start my blipping again!
I do have a SGII and I know that if I keep the "LOD" down below 86 I will stay in closed loop mode. Through a little in-town driving today, I have managed to repeat my WOT LOD at 78 almost every time, if not just a tad below.
Thanks guys! :thumbup:
SentraSE-R 06-09-2010 12:31 AM
I barely kiss the clutch plates to start the engine. Then I rev match to pulse again. 83 LOD works well for accelerating in both my SE-R and xB. 83 LOD is moderate acceleration in the xB. It's spirited acceleration in the SE-R.
