Purpose of these?
http://farm3.static.flickr.com/2635/...f91e97fb32.jpg
Where the rear window should be, do they have a name? :confused: Mini-staggered-spoilers? I've also seen these on some Hondas, do they help FE at all? Or are they just aesthetic? |
Those are louvers, no aero benefit that I am aware of (possible aero penalty), thought they just helped keep a bit of sun out. It looks like your louvers have louvers :)
louvers camaro - Google Search |
They keep the sun out while still letting you see straight back, without them I'm not sure if anything but the strongest A/C could keep a car cool with a back window that size.
All this time I thought they were to keep the flux capacitor from overloading.
Used to see alot of hatchback cars with louvers in the 80's but not so much lately. |
Cool the flux capacitor, of course!
Louvers, so just a fad from the 80's huh? haha |
Consider/consult this EM thread: http://ecomodder.com/forum/showthrea...ent-17590.html
But I'm sure it also charged the flux capacitor, whenever garbage ran out, sorta like a trickle charger/maintainer. |
You could mount a trickle-charger solar panel on each of those and provide a lot of charging power! :D
I found HONDA louvers on my used CRX when I bought it. I know it's not perfect aero , but I appreciate being cooler in the car w/o AC. I've gotten 62.something mpg. 4 times on trips so far, so I don't consider it's weight penalty? that overwheming right now! The 1st gen. is nearly a modern classic, so the louvers fit the time period.
I think that they would help any car w flying buttresses type rooflines. Think of the factory re-do to make the Dodge Charger's rear window better for the Daytona version! I would think the '68-70 Chargers, the '66-59 GM intermediates such as Chevelle's, Skylark's etc... need the filler! The Pantera is very dirty aero wise in this area, Fiero's, X1/9's, and so on, and on! It would seem that louvers would have some down force effect, w/o the added penalty of traditional stand up, or lip spoilers? I find the mesh venting? on the lowest tier of the pictured Delorean interesting! Would that act, and position qualify TO be called a spoiler???? Interesting subject! Some holes need to be filled on some cars. I think the Pantera, and X1/9 make that obvious, that w/o a complete Daytona like redo; the louvers are the best Bandaid??? I know the Fiat is almost PU like, and actually needs flying buttresses for look's improvement! |
I believe on a Dolorean it was the engine lid and there was a flat window right behind the drivers head. I don't remember to well but I think it's like a fiero GT in back, the rear side windows were windows for a nicer side profile and some aero benefits.. I would add the same thing If I did a Fiero GT project.This actually helps the flow of air smooth and it is the "louvered Engine Bay Lid" Whatever is under that louvered Lid is a totally seperate compartment from the passenger compartment. I also believe engine bay heat left through those louvers also.
If you look at this photo, It was actually an aerodynamic mod and sorta funny that you had to open 2 lids to get to the engine which was a POS IMO! http://www.influx.co.uk/wordpress/wp...l6fo1_1280.jpg I hope this helped you guys know it isn't to keep the driver cool at all! lol |
Obviously not everyone has had the chance to see and ride in a real one before but I think it is funny how people think they know what they are talking about and only a few know. |
