Push-button Ignition how-to
How to install a push-button ignition for use at stop lights. The idea is this: you start car normally with the key, drive until you reach a long light, press the kill button[work in progress] to stop motor, when ready to go, press the start button.
This is how I wired mine. Unless you have an 80's or 90's Chrysler or derivative, you will need to do it differently. Pressing the button with out the key in the 'run' position will crank the starter, but the fuel pump will no turn on, also you can't shift out of park or unlock the wheel. BOM: 1x N/O momentary SPST push button switch 2x SPDT 10A, 12v coil, relays 1x Plastic box 3x 3M 905 snap-down wire taps Wire of appropriate gauge Other stuff like zip ties, tools, magnetic tape #1 Acquire very affectionate stray cat to lend a helping paw. I don't know who owns him, but he always joins me when I work on my car at night. http://farm4.static.flickr.com/3058/...5dbb1db2_b.jpg #2 Take apart steering column and lower dash. The blue twine will be used to fish the wires through the protective shroud. http://farm4.static.flickr.com/3097/...c58e527b_b.jpg #3 This is the ignition switch harness. Pin numbering goes from right to left, with yellow being pin one, and red being pin 7. On my car , when the key is in the 'run' position, pins 1&7 3&7 must be connected to start the engine. Pin 7 also provides the power to drive the relays. http://farm4.static.flickr.com/3060/...ef41590b_b.jpg #4 Tap switch wires. Make sure that the taps don't interfere with the tilt mechanism. Ignore the cruise control harness on the left. http://farm4.static.flickr.com/3281/...78b44da3_b.jpg #5 Wire relays and run wires into/out of box. Black wires on the right go to the taps, wires on the left go to the button and a ground lead for the relay coils. http://farm4.static.flickr.com/3017/...a08b6f7e_b.jpg The relays in this schematic are drawn strangely, I had to correct something after I scanned the drawing. http://farm4.static.flickr.com/3189/...0acf2d5d_b.jpg #6 Install push button. I'm putting in right next to the shifter, so i don't have to move my hand from the knob . http://farm4.static.flickr.com/3190/...961a5a4b_b.jpg The second hole is for a future kill switch. http://farm4.static.flickr.com/3281/...f7fac95b_b.jpg #7 Install box. Tuck wires away. The box is being held in place by magnetic tape. The wires have been routed under the dash and held in place by zip ties, leaving some slack for when the wheel is tilted. http://farm4.static.flickr.com/3066/...656f8240_b.jpg That's all 'till mornin' |
Thanks, great how-to. Looking forward to the kill switch too.
Very nice. I was looking for a way to do this. Now I have a much better idea, thank you!
Looks nice wikityler. I remember this from another thread and I like the professional look you're going for. One suggestion, when you install the starter switch, find the kind with a safety cover you have to flip up first so it doesn't accidentally get tripped while the engine is running. Since you've mounted it on a horizontal surface, if something falls on it, a cat for example, that could be really hard on your starter if the engine is running. Keep up the good work.
With this, will the radio still cut off when you push the button? (It does it in mine when I use the key, but if I install a button I hope that it doesnt cut off anymore)... ??
And why two relays instead of just one? |
Acc 6&7 Run 2&7, 4&5 Start 2&7, 1&7, 3&7 |
I used two SPDT relays because they were cheaper than one DPDT relay with the appropriate current rating. |
Nooooo no fancy audio system haha, just stock.
What I am thinking about is probably adding a small capacitor or rechargable battery inline with the power wire to the radio so that even if the power from the battery cuts out the radio still has enough electricity to run for that 1 second that it takes for the car to start. (again, its not long but it gets annoying, especially for other passangers, they dont like the radio cutting off at every stop light hahaha). |
They actually make very large capacitors (in excess of a Farad) just for surge protection in car A/V equipment.
I have bypassed the key in 3 or 4 beaters. a couple toggle switches for the ACC and On positions and a push button. I have found the key switch is the culprit in the radio and accessery shut off. When the key switch is in the start position only the On and Start posts get power. Bypassing the key switch will usualy mean that pushing a button for start will just activate the starter, without interupting the power to the fuse block (and radio)
Thanks for the write-up:thumbup:
Yea, I'm interested in doing this on my beetle. It just seems like the right thing to do. I'm curious, though. It seems like my steering column tightens up in my beetle, but in my wife's jetta it remains the same. What can be done for this?
