Putting a Metro transmission back together
4 Attachment(s)
How I spent 12 hours on a Saturday with a 1993 Metro transmission and a friend...
The exposed gears in the main case: http://ecomodder.com/forum/attachmen...1&d=1409632044 Inspecting synchros: http://ecomodder.com/forum/attachmen...1&d=1409632044 That odd fifth gear spot (gears not yet in place) outside the main case: http://ecomodder.com/forum/attachmen...1&d=1409632044 Aha! It's not in neutral: http://ecomodder.com/forum/attachmen...1&d=1409632044 That was the first time I have worked with an opened-up transmission. Very useful for developing greater familiarity with them for my own transmission rebuild sometime, maybe next year (I hope). |
So is it all back together? This was for the final drive swap?
I don't think the external 5th is that unusual (for cars of that vintage, anyway -- can't speak for more modern ones). |
The first Z car 5 speeds had the 5th gear behind the center plate and the main case. Reverse gears were behind that. 4th gear just locked the imput shaft to the main shaft and it was direct drive. The counter shaft did not even need to be in the case for 4th to work. My doctors D21 pickup sheared the key off the front counter shaft gear to the input shaft. He made it to the shop using only 4th gear.
regards Mech |
Last time I was out there I suggested the swap, since it was off, but he didn't want the expense and fretted about climbing hills. "Just shift down" was not a convincing response. Was a good time though, and another Metro transmission has been put back on the road... |
I bet that transmission would have fared just fine with that small meal of cork. Probably good for it!
